查看: 16608|回复: 10
[求助] system verilog keyword 'class' is not expected to be used in this context
发表于 2014-12-25 17:07:41 | 显示全部楼层 |阅读模式
这是本人在编写简单的验证平台时遇到的一个问题,看了case1.sv也没看出什么问题,请各位大神指教
编译错误如下:
Error-[SE] Syntax error
  Following verilog source has syntax error :
  "case1.sv", 4: token is 'class'
  class case1 extends uvm_test;
  System verilog  keyword 'class' is not expected to be used in this context.
1 warning
1 error
CPU time: .694 seconds to compile
case1.sv内容如下:
`ifndef CASE1_SV
`define CASE1_SV
        data_config data_cfg;
        img_set_config img_set_cfg;
        `uvm_component_utils(case1)
        mod_adp_driver mod_adp_drv;
        mod_adp_sequencer mod_adp_sqr;
        function new(string name = "case1", uvm_component parent = null);
                super.new(name, parent);
        endfunction
        virtual function void build_phase(uvm_phase phase);
                super.build_phase(phase);
                mod_adp_drv = mod_adp_driver::type_id::create("mod_adp_drv", this);
                mod_adp_sqr = mod_adp_sequencer::type_id::create("mod_adp_sqr", this);
                data_cfg = data_config::type_id::create("data_cfg", this);
                data_cfg.build();
                uvm_config_db#(data_config)::set(this, "mod_adp_sqr.*", "data_cfg", data_cfg);
                img_set_cfg = img_set_config::type_id::create("img_set_cfg", this);
                img_set_cfg.build();
                uvm_config_db#(img_set_config)::set(this, "mod_adp_drv", "img_set_cfg", img_set_cfg);
                uvm_config_db#(uvm_object_wrapper)::set(this, "mod_adp_sqr.main_phase.*", "default_sequence", mod_adp_sequence::type_id::get());
        endfunction
        virtual function viod connect_phase(uvm_phase phase);
                super.connect_phase(phase);
                mod_adp_drv.seq_item_port.connect(mod_adp_sqr.seq_item_export);
        endfunction
endclass
`endif
发表于 2015-10-10 11:13:23 | 显示全部楼层
请问你这个问题解决了吗?我也遇到了同样的问题
 楼主| 发表于 2015-10-10 16:33:36 | 显示全部楼层
回复 2# chenxl1990
    解决了,不过时间太久了,记不清了,应该是代码问题,最好仔细检查一下在该报错的文件之前编译的那个文件
发表于 2015-10-10 16:41:17 | 显示全部楼层
好的,谢谢哈,遇到这个问题一直找不出来具体错在哪
发表于 2015-10-10 17:23:29 | 显示全部楼层
回复 4# chenxl1990
我也遇到过,也记不清了。好像是我在windows下编辑的时候把文本格式搞错成utf-8了,后来用nedit打开,可以看到前面有个特殊字符。
发表于 2015-11-25 16:01:51 | 显示全部楼层
你好,我也遇到这个问题了,请问你是如何解决的?
发表于 2016-9-27 17:17:33 | 显示全部楼层
来自:https://verificationacademy.com/ ... s-declaration-issue
Usually a problem like this is because of an unfinished declaration that comes before it.
It would be much easier to find these kinds of problems if you did not `include everything in to one big file and could separately compile things. Our recommendation is to put each class in a separate file, and `include each class a package. Then you can compile each package independently. See an example of this here: http://verificationacademy.com/u ... rificationComponent
发表于 2017-1-19 13:26:39 | 显示全部楼层
回复 7# 香香瓜
   Thanks for your kindly reply.
发表于 2019-11-5 16:32:48 | 显示全部楼层
检查下,是否import uvm_pkg::*; 漏了 ";"
发表于 2019-11-26 20:51:59 | 显示全部楼层
报错的位置没有错,应该是你编译的上一个文件有语法错误
GMT+8, 2025-12-23 00:47 , Processed in 0.025504 second(s), 7 queries , Gzip On, Redis On.
