楼主: min4max
Mentor Calibre2014的license新增FEATURES极其环境变量设置
发表于 2017-1-13 19:14:09 | 显示全部楼层
回复 45# xiaoquanic
   运行后报 Calibre RealTime Error: Mentor Calibre OA observer is not loaded, check your LD_LIBRARY_PATH setting!应该是这个错误的原因
*WARNING* (DB-220704): The Pcell super master: MentorObserverLib/MentorObserver_master/layout is not a SKILL super master.
这个文件的Pcell 不支持到底是个什么问题?谢谢
发表于 2017-1-16 18:36:42 | 显示全部楼层
回复 61# rfham
error 怎么解决的想不起来了,warning的话,你看看这篇文章http://www.eda.ncsu.edu/wiki/FreePDK45:Using_P-Cells
发表于 2017-1-17 14:08:10 | 显示全部楼层
回复 14# brightorange
   兄弟你好,我的calibre安装好后,单独使用calibre -gui没有问题,lic只保留feature行,没有server/daemon行,bashrc里面直接lic指到lic.dat文件上,但是在ic617上开启了calibre realtime后,出现了一个warning 和一个error\o Successfully checked out 'Virtuoso_MixedSignalOpt_Layout' license.\o //\o //  Calibre Skill Interface * (v2016.4_27.18) *\o //\o //                 Copyright Mentor Graphics Corporation 2005\o //                             All Rights Reserved.\o //         THIS WORK CONTAINS TRADE SECRET AND PROPRIETARY INFORMATION\o //            WHICH IS THE PROPERTY OF MENTOR GRAPHICS CORPORATION\o //              OR ITS LICENSORS AND IS SUBJECT TO LICENSE TERMS.\o //\o //\p > \o Loading pe.cxt \a _treeSetOpcGUI(t)\r t\o //  Calibre layout-server initialized successfully at socket 9189, host xxx.\# Memory report: using         316 MB, process size 1,188 MB at UTC 2017.01.16 08:09:07.507\w *WARNING* (DB-220704): The Pcell super master 'MentorObserverLib/oa_v22_50_001/layout' is not a SKILL super master.\w                        The usage of non-SKILL Pcells in Virtuoso is not a supported feature.\o //  Calibre v2016.4_27.18    Tue Dec 6 11:51:00 PST 2016\o //\o //        Copyright Mentor Graphics Corporation 1996-2016\o //                       All Rights Reserved.\o //   THIS WORK CONTAINS TRADE SECRET AND PROPRIETARY INFORMATION\o //      WHICH IS THE PROPERTY OF MENTOR GRAPHICS CORPORATION\o //        OR ITS LICENSORS AND IS SUBJECT TO LICENSE TERMS.\o //\o //  Mentor Graphics software executing under x86-64 Linux\o //\o Calibre server launched successfully\o //  Calibre RealTime embedded client initialized successfully at xxx:9189\o // Calibre RealTime: Error ERROR_LICENSE_ACQUIRE: Problem acquiring license(s)
请问realtime这个error你遇到过吗,上述两个问题怎么解决的?谢谢
发表于 2017-3-24 23:55:02 | 显示全部楼层
能否生成 floating license 呢?
发表于 2017-5-6 12:47:27 | 显示全部楼层
谢谢分享!
发表于 2017-6-20 14:31:24 | 显示全部楼层
有0in吗
发表于 2017-7-20 21:23:24 | 显示全部楼层
mark,谢谢分享
发表于 2017-11-11 16:28:08 | 显示全部楼层
谢谢楼主分享!
发表于 2018-3-14 08:47:13 | 显示全部楼层
calibre mark
发表于 2018-7-24 20:02:45 | 显示全部楼层
来学习的,感谢楼主的探索和分享精神。
GMT+8, 2025-12-28 22:27 , Processed in 0.019099 second(s), 3 queries , Gzip On, Redis On.
