查看: 2798|回复: 2
[求助] ELC仿真D触发器不能识别
发表于 2014-12-11 17:08:51 | 显示全部楼层 |阅读模式
自己画了带复位的D触发器,然后写了gate文件:DESIGN ( DFCND );
//       PORT DEFINITION
INPUT CP ( CP );
INPUT D ( D );
INPUT CDN ( CDN );
OUTPUT QN ( QN );
OUTPUT Q ( Q );
SUPPLY1 VDD ( VDD );
SUPPLY0 VSS ( VSS );
//       INSTANCES
IMUX ( XP, CP, P, D );
NAND ( P, XP, CDN );
IMUX ( QN, CP, P, Q );
NAND ( Q, QN, CDN );
END_OF_DESIGN;
可是不能正确识别前一级锁存结构:
      DESIGN : DFCND2
[WARNING(db_gsim)] illegal function in gate file :
- register(Q,QN) is recognized.
- loop recognition error ( multi stage ) loop( imux: $2 nand: $1 )
- loop node ( $1 ) is found
- loop node ( $2 ) is found
- naked output ( Q ) is found
- naked output ( QN ) is found
怎么办?
发表于 2025-3-4 16:54:37 | 显示全部楼层
请问你后来是怎么解决的,我也是,
 楼主| 发表于 2025-3-22 23:09:30 | 显示全部楼层
xinghongbo 发表于 2025-3-4 16:54
请问你后来是怎么解决的,我也是,
手动声明了那个地方有一个DFF,具体咋解决的我已经忘了,已经十年了
GMT+8, 2025-12-30 01:04 , Processed in 0.017680 second(s), 6 queries , Gzip On, Redis On.
