查看: 1193|回复: 0
[招聘] Cadence SH 招聘Principal/Lead Customer Support Engineer -DDR PHY
发表于 2014-12-9 18:04:35 | 显示全部楼层 |阅读模式
Cadence SH 招聘Principal/LeadCustomer Support Engineer -DDR PHY
更多职位信息敬请关注Cadence公众微信平台:Cadence中国招聘
If you have interest, PLS send your updateCV to zhangyl@cadence.com
Title: Principal/Lead Customer Support Engineer -DDR PHY
Position Description:
Cadence is looking foran individual to work in an established DDR Design IP team. The group providesconfigurable DDR memory controller and PHY IP for ASICs. The job will befocused on providing technical support to customers, however there will be avariety of other engineering tasks that will allow the candidate to expandskills and responsibilities.
Provide technicalsupport to customers for integration of IP into ASICs including:
- Debugging ofcustomers’ simulation or silicon issues
- Reviewing ofcustomers’ integration of our IP
- Reviewing statictiming reports to assist with customers’ timing closure
- Answering technicalquestions about IP operation
- Train fieldengineers in IP operation
- Interface with theR&D and marketing teams to make product improvements and resolve customerissues
Position Requirements:
Essential Skills andexperiences needed:
- Excellent oral andwritten communication skills in Chinese and English
- All front-end skills– RTL design & verification in Verilog, synthesis, static-timing analysis,DFT
- Time managementskills sufficient to balance multiple high-priority projects
- Willingness to learnnew skills and perform tasks that often go outside area of current expertise
Additional DesirableQualifications:
- Back-end skills –place & route, physical verification, timing closure, power analysis
- Experience withStatic Timing scripts and report analysis
- Familiarity with DDRmemory operation, system applications, AMBA protocols
- Scripting in Perl,TCL, etc.
GMT+8, 2025-12-27 12:14 , Processed in 0.071596 second(s), 7 queries , Gzip On, Redis On.
