查看: 1578|回复: 0
[招聘] NO.78-Sr. / Staff Customer Engineer or CE Manager(Shanghai)
发表于 2014-12-8 14:56:33 | 显示全部楼层 |阅读模式
Job Descriptions:
回答客户对foundry process的技术问题,包括:
  工艺能力的咨询;
  工艺的良率以及可靠性;
  客户在设计中遇到跟foundry相关的设计问题,比如tech file和spice model;
负责帮助客户顺利在foundry tapeout:
  检查客户的tapeout表格;
  DRC,DFM相关问题确认;
  JDV相关问题确认;
产品良率跟踪以及问题处理;
产品qualification结果跟踪
Job Requirements:
至少在foundry有5年(Manager需要10年以上)的工艺整合和器件工程经验;
至少开发过2~3代工艺,并将至少2个产品代入量产阶段;
有半导体物理器件知识;
电子工程或固体物理学士学位及以上;
有IC设计和测试经验者更佳;
有良好的沟通技巧,能和客户保持好的关系。
KT Human Resources Consulting Company (Shanghai) was established in 2001 in response to a need for a recruitment consultancy to be an active, contributing member of the semiconductor community, as opposed to simply a supplier to it.We provide professional search and talent acquisition in the Integrated Circuit、Electronic、Telecommunications industry of international corporations in Greater China. Our client list contains numerous international companies, many of them are long-term customers.
If you interested in the job, pls sent your cv to: hr@kthr.com, thanks!
“KT人才”微信也可查询职位啦!打开手机微信,搜号码“KTHR_COM”或查找微信公众帐号“KT人才”即可添加,欢迎大家关注!(关注成功后输入”KT“即可查询职位!)
GMT+8, 2025-12-27 06:39 , Processed in 0.014663 second(s), 7 queries , Gzip On, Redis On.
