查看: 2463|回复: 3
HDL.Works.HDL.Desing.Entry.ConnTrace.v1.2.R1.for.Windows.&.Linux + CRACK
发表于 2014-12-7 10:21:23 | 显示全部楼层 |阅读模式
HDL.Works.HDL.Desing.Entry.ConnTrace.v1.2.R1.for.Windows.&.Linux-BEAN + CRACK
ConnTrace
Automatically verifying
thousands of connections between PCBs
When developing large electronic systems consisting of multiple Printed Circuit Boards (PCBs), making sure that each signal is connected to the correct pin of a connector is a cumbersome task. Until now there has not been a way to verify these connections automatically and designers were forced to manually check each connector pin.
Using ConnTrace you can process a number of netlists (which may be in different formats), define the connections and trace the signals from board to board.
Intelligent Verification
ConnTrace uses rules (based on regular expressions) to match the signal names between PCBs. It allows the tool to validate groups of matches although individual signals can still differ. The rules can be generated automatically and be fine-tuned by the designer. The automated approach will often match 80% to 90% of all connector pins.
The flexibility of ConnTrace allows it to be used in any design flow and does not require any design methodology. The rule generator in combination with the sorted problem view allows engineers to validate large systems in a few hours.
Once the project and its rules are defined it is a simple task to re-verify the connectors when changed were made to the PCBs. All out-of-date files are processed in one action.
Features & Benefits
  • Compare PCB signal/pin names using regular expressions
  • Automatic rule generation
  • User directed acceptance of verified differences
  • One click verification and consistency
  • Reports incremental changes in pin- and net list
  • Concentrate on a dozen differences instead of a thousand lines
  • Fits in any design flow
  • HTML report
HOME
  1. http://www.hdlworks.com/products/conntrace/index.html
    复制代码
Free 14 day trial
  1. http://www.hdlworks.com/products/conntrace/trial.html
    复制代码
UnRAR Password/Passcode: eetop.cn
!!!Please verify downloaded files against the checksums listed below to see whether all are OK!!!
029da7911dba833c37b561f0db3b89726af670ed *HDL.Works.HDL.Desing.Entry.ConnTrace.v1.2.R1.for.Windows.&.Linux-BEAN.part1.rar
31ce2d71b80ff447e23a4fa88b522f0d29fd44f0 *HDL.Works.HDL.Desing.Entry.ConnTrace.v1.2.R1.for.Windows.&.Linux-BEAN.part2.rar
3a23fee07d6b03d1e2792cfd61d069b27a32ac29 *HDL.Works.HDL.Desing.Entry.ConnTrace.v1.2.R1.for.Windows.&.Linux-BEAN.part3.rar
SHA1SUM
HDL.Works.HDL.Desing.Entry.ConnTrace.v1.2.R1.for.Windows.&.Linux-BEAN.sha.docx (369 Bytes , 下载次数: 13 )
15 MB, 下载次数: 41 , 下载积分: 资产 -5 信元, 下载支出 5 信元
15 MB, 下载次数: 37 , 下载积分: 资产 -5 信元, 下载支出 5 信元
10.07 MB, 下载次数: 71 , 下载积分: 资产 -4 信元, 下载支出 4 信元
发表于 2014-12-7 12:05:00 | 显示全部楼层
感谢分享
发表于 2015-9-24 23:34:19 | 显示全部楼层
发表于 2016-8-11 09:42:47 | 显示全部楼层
这个工具可以提高效率啊。也可以用EXCEL开发类似的工具
GMT+8, 2025-12-23 17:41 , Processed in 0.035151 second(s), 7 queries , Gzip On, Redis On.
