查看: 7927|回复: 14
[求助] 复旦大学RFIC实验室
发表于 2014-11-27 16:55:48 | 显示全部楼层 |阅读模式
想了解一下  复旦大学RFIC实验室  博士待遇如何?  另外,要达到什么要求才能毕业?
发表于 2014-11-27 17:18:12 | 显示全部楼层
According to the regulations, the phd candidates that receivered master degree generally stay there 3-4 years, others except engineering-orientation phd candidates at least  dedicated themselves   for 5 years there.
two journal or conference papers must be published in SCI.
you probably get 2000~3000 RMB each month as a living compensation.
moreover, you will be awarded 2W RMB each one when releasing some top papers, such as ISSC, JSSC.
发表于 2015-1-3 21:44:58 | 显示全部楼层
It's a very high quliity phd
发表于 2015-1-18 17:18:02 | 显示全部楼层
博士待遇将要提升
发表于 2015-1-18 17:20:07 | 显示全部楼层
这个地方很不错
发表于 2015-1-18 17:20:49 | 显示全部楼层
4年,可以考虑一下,毕竟RF需要这么久的功底
发表于 2015-3-2 22:41:37 | 显示全部楼层
回复 1# happily0221
really interested in RFIC and can bear stress, it will be your luck to go there.
发表于 2015-3-17 15:37:26 | 显示全部楼层
回复 2# angelaboy
Only 2W RMB each one, are you kidding? In Korea,its 5000 dollars.
发表于 2015-3-21 11:25:47 | 显示全部楼层
zhichi
发表于 2015-3-27 02:22:25 | 显示全部楼层
值得!!!
GMT+8, 2025-12-26 15:57 , Processed in 0.025433 second(s), 5 queries , Gzip On, Redis On.
