查看: 1138|回复: 0
[招聘] 【Marvell招聘】Senior Physical Design Engineer
发表于 2014-11-25 15:31:56 | 显示全部楼层 |阅读模式
Job Title: Senior Physical Design Engineer
Essentialskills:
MS in EErequired.
·Proventrack records of working independently on place-and-routeproject running and DRC/LVS/ERC/Antenna debugging skills
·Experiencewith Magma or Synopsys place-and-route tool set and physical design projectimplementation.
·Goodprogramming skill.
·Capable ofwriting Tcl or Perl.
·Familiarwith synthesis,static timing analysis.
·Self-motivatedteam worker, good verbal and written communication skills in English.
·Technicaland team leadership proffered. Previous management experience highly desired.
·Experiencewith synthesis, DFT, and verification is preferred.
KeyResponsibilities
Depending onexperience, key responsibilities will involve some of the following:
·ICimplementation from netlist to gdsii, with synthesis,floorplanning, place and route, timing closure, andphysical verification.
·As a keymember of physical design team, your will work on one of most advanced and themost complex chip Marvell designed.
·Leading ateam of physical design engineers and resolving the technical related issues.
·Crosstalkanalysis, power analysis, and static timing analysis.
·Writescripts in Tcl to improve productivity.
If you have any interest in the position, please send your bilingual resume as attachments to emilyye@marvell.com or marvellresume@126.com
Subject of your email should be “Your Name_University_Applied Position Title”
GMT+8, 2025-12-27 10:43 , Processed in 0.020022 second(s), 6 queries , Gzip On, Redis On.
