查看: 3249|回复: 1
silvaco中 deckbuild 直接保存文件到指定文件夹
发表于 2014-11-18 21:49:43 | 显示全部楼层 |阅读模式
小弟新接触silvaco,很多不懂的求大神赐教。我读书少,不要笑话我的无知
如题,在deckbuild窗口中 如何保存文件到指定的文件夹
例如 structure outfile=filename.str
想要把filename.str文件直接保存到指定的文件夹下 应该怎么写?
发表于 2015-6-21 17:26:30 | 显示全部楼层
Based on my experiences, you cannot save files to the desired folder by simple setup or clicks. To overcome this, I wrote a loop or something like that in the code to automatically save the files to the folder that I want the files to be saved in. You may try that...
GMT+8, 2025-12-22 13:27 , Processed in 0.016868 second(s), 8 queries , Gzip On, Redis On.
