查看: 5306|回复: 13
Cadence 166 Hotfix 039
发表于 2014-11-16 14:25:14 | 显示全部楼层 |阅读模式
DATE: 11-14-2014   HOTFIX VERSION: 039
CCRID   PRODUCT        PRODUCTLEVEL2   TITLE
1213239 FLOWS          PROJMGR          SPI_ERROR: Missing closing quote at line 41 in""
1301262 SPIF           OTHER            When creating .dsn file for designs containing netclasses with net groups, PCB Editor stops responding.
1301469 CONCEPT_HDL    CORE             DE-HDL Import Design - Need a directive to enable the "Retain Hard Packaging Information" option by default
1309535 SYSTEMSI       ENG_PBA          PA5700: Cannot print, save, or post process SI analysis reports
1317019 SIG_INTEGRITY  LIBRARY          Buffer model for pins not changing correctly when multiple DML files are present in working directory.
1318452 ALLEGRO_EDITOR DATABASE         Derive Connectivity does not update connections; DRC errors thrown
1318610 CONCEPT_HDL    CORE             DE-HDL does not re-validate/re-read DML files on disk upon launching Constraint Manager
1320997 CAPTURE        SCHEMATIC_EDITOR Copy paste of multiple images are stacked in same place.
1321377 FSP            GUI              FSP crashes while performing copy-paste operations between different arrays in the Rule text editor
1321513 ALLEGRO_EDITOR SYMBOL           Preview not available for DRA
1324479 ALLEGRO_EDITOR OTHER            Option specified in license_packages_allegro.txt file but missing in license server causes Segmentation fault on LINUX
1327962 FSP            MODEL_EDITOR     Need ability to select multiple pins in the Preview area of Rule Editor
1328633 CONCEPT_HDL    CORE             On running Save All, changes were partially saved before DE-HDL crashed.
1328921 ALLEGRO_EDITOR DATABASE         Running Derive Connectivity followed by Database Check throws SPMHUT-17 error
1330029 CONCEPT_HDL    CORE             PIN_TYPE and PINUSE attributes not updated consistently in DE-HDL design
1330580 SIP_LAYOUT     SYMB_EDIT_APPMOD When adding a pin using the Symbol Editor the Pin Name is being changed if duplicated
1331028 CONCEPT_HDL    CHECKPLUS        Rules Checker fails on DE-HDL component.
1331051 ALLEGRO_EDITOR INTERFACES       Soldermask layer is mapped to both Soldermask solderPaste and Miscellaneous Image Layers columns using IPC-2581B
1333127 CONCEPT_HDL    CORE             Sheet number in the new window is only the block-level number and not the design-level number
1333591 SIP_LAYOUT     SKILL            Difference in behavior for padstack replace using axlPadstackReplace and command Replace Padstack
1333896 ASI_SI         OTHER            signoise -f and -k options don't work for net names with consecutive underscores.
1333982 ALLEGRO_EDITOR ARTWORK          ARTWORK: Coordinates of the hole get shifted by the "Draw holes only" option.
1334302 CONSTRAINT_MGR SCHEM_FTB        Import Logic - Import changes only or Overwrite current constraints fails to update signal models.
1335276 CONCEPT_HDL    OTHER            On selecting objects near the schematic page border, the border is also selected
1336322 CONCEPT_HDL    CORE             DE-HDL does not open with maximized window.
1336783 PCB_LIBRARIAN  IMPORT_EXPORT    con2cap fails to export the part to OrCAD Capture format
链接:http://pan.baidu.com/s/1dDxS2Xz 密码:2ubn
发表于 2014-11-16 17:28:21 | 显示全部楼层
怎么说来着,我跟你讲说用scl的lmtools或者命令行直接挂起license,你又不信
╮(╯_╰)╭
 楼主| 发表于 2014-11-16 18:01:52 | 显示全部楼层
老大看下面的那个。
这个是用cadence的lmtool读出来的。
 楼主| 发表于 2014-11-16 18:02:06 | 显示全部楼层
需要的下载。
 楼主| 发表于 2014-11-16 18:03:09 | 显示全部楼层
    你说的太高深了,怎么用scl的license tools呢?
 楼主| 发表于 2014-11-16 19:03:45 | 显示全部楼层
安装了SCL11.8,log 文件附上,老大帮忙看看呗。 log.rar (14.54 KB , 下载次数: 0 )
 楼主| 发表于 2014-11-16 20:51:14 | 显示全部楼层
suiwinder 发表于 2014-11-16 18:03
这个是log file,用SCL 11.8产生的,貌似都已经安装好了,怎么还不行呢?有同样的提示。
另外,设置环境变量的时候,变量名是LM_LICENSE_FILE还是CDS_LIC_FILE?
    log.rar (53.09 KB , 下载次数: 3 )
 楼主| 发表于 2014-11-16 21:13:58 | 显示全部楼层
╮(╯_╰)╭
snk88 发表于 2014-11-16 17:28
貌似这次改好了,还是不行
    log.rar (14.37 KB , 下载次数: 5 )
发表于 2014-11-16 21:45:25 | 显示全部楼层
saber RD2013.12.1那里有下?
发表于 2014-11-16 21:46:47 | 显示全部楼层
saber RD 2013.12.1那里有下?
GMT+8, 2025-12-21 23:59 , Processed in 0.028368 second(s), 6 queries , Gzip On, Redis On.
