查看: 2458|回复: 0
[求助] ovm_update_sequence_lib_and_item与ovm_update_sequence_lib区别
发表于 2014-11-5 15:26:34 | 显示全部楼层 |阅读模式
看了下ovm库里面,他们俩的区别就是有两点,但是小弟对这两点理解得不是很透彻,希望大神多指点。
  1. // MACRO: `ovm_update_sequence_lib
  2. //
  3. // This macro populates the instance-specific sequence library for a sequencer.
  4. // It should be invoked inside the sequencer¿s constructor.
  5. `define ovm_update_sequence_lib \
  6.   m_add_builtin_seqs(0); \
  7.   ovm_update_sequence_lib();
  8. // MACRO: `ovm_update_sequence_lib_and_item
  9. //
  10. // This macro populates the instance specific sequence library for a sequencer,
  11. // and it registers the given ~USER_ITEM~ as an instance override for the simple
  12. // sequence's item variable.
  13. //
  14. // The macro should be invoked inside the sequencer's constructor.
  15. `define ovm_update_sequence_lib_and_item(USER_ITEM) \
  16.   factory.set_inst_override_by_type( \
  17.     ovm_sequence_item::get_type(), USER_ITEM::get_type(), \
  18.     {get_full_name(), "*.item"}); \
  19.   m_add_builtin_seqs(1); \
  20.   ovm_update_sequence_lib();
    复制代码
1.ovm_update_sequence_lib_and_item会将里面simple sequence的item类型改变为user定义的sequence里面的item类型
这个的话还比较好理解
2.m_add_builtin_seqs()这个函数参数一个是0,一个是1
我看了下这个函数的内容,如下。感觉就是添加了三个默认的系统自带的sequence。前两个自带的sequence会默认执行user定义的某些sequence,但最后一个simple_sequence的作用我还是真没看懂。
  1.   virtual function void m_add_builtin_seqs(bit add_simple = 1);
  2.     if(!sequence_ids.exists("ovm_random_sequence"))
  3.       add_sequence("ovm_random_sequence");
  4.     if(!sequence_ids.exists("ovm_exhaustive_sequence"))
  5.       add_sequence("ovm_exhaustive_sequence");
  6.     if(add_simple == 1)
  7.       if(!sequence_ids.exists("ovm_simple_sequence"))
  8.         add_sequence("ovm_simple_sequence");
  9.   endfunction
    复制代码
那么好,问题来了,请问ovm_update_sequence_lib_and_item与ovm_update_sequence_lib分别用在哪里?(自己感觉前者用于base的sequencer,后者用于extend的sequencer)
还有就是这个m_add_builtin_seqs的意义是什么?
simple_sequence难道会对应一个user自己定义的sequence来进行执行吗?
GMT+8, 2025-12-25 09:17 , Processed in 7.045823 second(s), 5 queries , Gzip On, Redis On.
