查看: 13310|回复: 10
Rsoft和Comsol哪个做光波导仿真好用啊?
发表于 2014-11-4 20:19:49 | 显示全部楼层 |阅读模式
发表于 2014-11-9 20:51:25 | 显示全部楼层
RSoft Component Suite 2013.12
http://filepost.com/files/54fa6623/ofRCoS131232b.rar32bit
http://filepost.com/files/bdb1d6d1/ofRCoS131264b.rar64bit
Synopsys, Inc., a global leader providing software, IP and services used to accelerate innovation in chips and electronic systems, presents version 2013.12 of the Synopsys RSoft products, its industry-leading family of software tools for photonic and optical network design. This release delivers new modeling and analysis features as well as simulation speed improvements in the RSoft Photonic Component Design Suite. In addition, the release delivers enhancements in the RSoft MetroWAND(TM) network design tool to streamline network modeling, design and service planning.
Enhanced Modeling of Optical Surface ScatteringTwo products in the Photonic Component Design Suite, the DiffractMOD(TM) and FullWAVE(TM) simulation tools, can now generate a Bidirectional Scattering Distribution Function (BSDF) file that contains scattering information for periodic optical structures, such as subwavelength diffractive surface gratings. The BSDF can be applied to a finite optical beam that covers more than one period to determine reflection and transmission characteristics of a structure. This provides a flexible, highly accurate method for modeling an optical surface's scattering properties, and helps optical designers achieve stringent size, weight and cost targets more easily.
The RSoft BSDF files can be imported into Synopsys' LightTools illumination design software to facilitate the design of lighting systems with small-feature, diffractive optical structures such as nano-structured LEDs. The BSDF data can also be used in Synopsys' CODE V® optical design software, in its Beam Synthesis Propagation tool. This enables efficient analysis of micro-optical components used in applications that incorporate both illumination and imaging elements, like digital projector systems.
Simulation Speed and Performance EnhancementsThe RSoft BeamPROP(TM) tool has enhanced multi-threading capabilities that dramatically improve simulation speed and new Perfectly Matched Layer (PML) boundary conditions that provide improved performance for complex radiation patterns. FullWAVE has optimized continuous wave (CW) dispersive simulations for improved simulation speed, as well as a new dispersion fitting utility to create dispersive material models to use in simulations for multi-wavelength systems.
Expanded Multi-Physics UtilityThe RSoft Multi-Physics Utility accounts for the effects of electrodes, heaters, stress and carriers on the refractive index profile during photonic device simulation. The Carrier Effects feature in this utility has been expanded to include:
- The ability to use complex index perturbations
- Generation of the photonic device's frequency response
- The ability to import custom, user-defined doping profiles
- Many new analysis outputs, including carrier density, current vs. voltage (I-V), resistance vs. voltage (R-V), and capacitance vs. voltage (C-V) plots
ROADM Network DesignMetroWAND 2013.12 delivers a new design engine option that allows flexible modeling and simulation of ROADM networks. Key capabilities include:
- Design and optimization of capacity allocation, end-to-end fiber layer performance validation and automatic selection and placement of ROADM network elements from the equipment library of choice
- End-to-end grooming of traffic demands into wavelengths
- Automatic setting of optical attenuators to equalize power of all optical channels
- Placement of optimal dispersion compensation modules in ROADM nodes
- Addition of Wavelength Selective Switch (WSS) models to the equipment library
- Ability to display the internal architecture of a ROADM node
- Support for automatic- or manual-selection nodes to build ROADM modules
Compliance with Optical Transport Network StandardsMetroWAND has new features to support the latest ITU-T OTN design standards, including:
- Rate Definition Model to support ITU-T G.709 Optical Transport Units (OTU) and Optical Data Units (ODU)
- Flexibility to add custom client signals and mappings
- Vendor equipment library samples to support OTN signal rates
发表于 2015-1-11 15:08:02 | 显示全部楼层
comsol运行比较慢,做能带图很麻烦
发表于 2015-4-17 14:52:33 | 显示全部楼层
Rsoft应该快点,我用Rsoft主要用来设计光子器件,很好用。comsol有同学用,感觉很好内存,而且也慢。
发表于 2015-5-23 10:01:14 | 显示全部楼层
rsoft应该更强大些
发表于 2016-4-18 18:58:42 | 显示全部楼层
RSOFT,不是给他们做广告哈。
发表于 2018-3-13 03:53:12 | 显示全部楼层
想要一个简单的用来算折射系数啥的软件
发表于 2020-5-24 17:35:21 | 显示全部楼层
請樓主分享
发表于 2020-5-24 17:41:11 | 显示全部楼层
adolph1988 发表于 2015-4-17 14:52
Rsoft应该快点,我用Rsoft主要用来设计光子器件,很好用。comsol有同学用,感觉很好内存,而且也慢。 ...
請樓主分享
都強大
发表于 2021-10-14 13:44:42 | 显示全部楼层
RSoft is better than Comsol.
GMT+8, 2025-12-15 04:17 , Processed in 0.102543 second(s), 8 queries , Gzip On, Redis On.
