查看: 1201|回复: 0
[招聘] 【Marvell全职】Engineer, Senior Applications HW
发表于 2014-11-3 14:02:27 | 显示全部楼层 |阅读模式
JobTitle: Engineer, Senior Applications HW
Department: CCBU
ExternalDescription:
SeniorRF/Hardware application engineer to work on technical support forWiFi/Bluetooth/GPS hardware.
1) ReviewWiFi/Bluetooth/GPS hardware design (schematic/PCB) on embedded/mobile/routerplatforms.
2) SupportWiFi/Bluetooth/GPS calibration and testing.
3) DebugWiFi/Bluetooth/GPS hardware issues on different platforms.
4) Writeapplication notes and technical documents.
5) Providecustomer support remotely or onsite as needed.
Qualifications
1) MS inEE, CE, CS or equivalent is required.
2) 2+ yearsrelevant software development and debugging experience is required.
3) Experiencewith C programming and debugging is required.
4) Experiencewith Linux kernel and driver or Windows driver development is required.
5) FluentEnglish (spoken and written) is required.
6) Knowledgeof WiFi/Bluetooth/GPS is preferred.
7) Experiencewith Java programming and Android framework is preferred.
8) Willingto travel as needed.
If you have any interest in the position, please send your bilingual resume as attachments to adahe@marvell.com
Subject of your email should be “Your Name_University_Applied Position Title”
GMT+8, 2025-12-27 12:14 , Processed in 0.144040 second(s), 3 queries , Gzip On, Redis On.
