查看: 6680|回复: 3
hspice error求助!
发表于 2014-10-24 13:03:56 | 显示全部楼层 |阅读模式
第一次用hspice,好不容易装好了又要破解,破解好了但是仿真跑不出来,不知道是装的方式不对还是代码不对或者是什么地方设置不对。。求助!ps菜鸟一枚不要嘲笑人家= = 图像 3.png
.title CS
mno  vout  vin  0  0  nmos_3p3   w=1u  l=0.35u
RR0  vdd   vout  10k
.LIB "C:\sm046005-1e.hspice"
vdd vdd 0 3.3
v1 vin 0 1.2
.dc v1 0 3.3 0.1
.op
.end
为什么title会是?title呢?
Command line options: -i a.sp -o a.lis
  lic:
  lic: FLEXlm: v10.9.8
  lic: USER:   Samsung              HOSTNAME: Samsung-PC
  lic: HOSTID: "24fd5287e275 1867b04d66f7 24fd52886c45" PID:      5032
  lic: Using FLEXlm license file:
  lic: C:\synopsys.dat
  lic: Checkout 1 hspice
  lic: License/Maintenance for hspice will expire on 31-dec-2019/2019.12
  lic: NODE LOCKED license on hostid "24fd5287e275 1867b04d66f7 24fd52886c45"
  lic:
Init: read install configuration file: C:\synopsys\Hspice_I-2013.12-SP1\meta.cfg
**error** (a.sp:1)syntax error at or before "t" "i" "t" "l" "e" " " "C" "S"
               ***** job aborted
  lic: Release hspice token(s)
lic: total license checkout elapse time:        4.36(s)
那么问题来了。。标题也有问题吗= =大家帮帮我吧感激不尽!
发表于 2014-10-24 21:18:33 | 显示全部楼层
回复 1# yayuyoulan
   第一行默认是注释行,不过还是写成以*开头比较好。还有要加个.option post
发表于 2015-10-28 12:19:56 | 显示全部楼层
zheyang也可以!!!
发表于 2017-3-23 23:15:46 | 显示全部楼层
楼主最后怎么解决的
GMT+8, 2025-11-5 00:32 , Processed in 0.016676 second(s), 6 queries , Gzip On, Redis On.
