查看: 1619|回复: 0
[招聘] Nvidia --GPU ASIC Physical Design engineer内推
发表于 2014-10-20 17:53:27 | 显示全部楼层 |阅读模式
Please sent resume to hbaifenbai@126.com if you are intested in this position
1. Position Title:GPU ASIC Physical Design engineer
As a senior member of our ASIC-PD team, you'll be working on streamlining the chip infrastructure process across product designs, focusing on full chip layout planning (partitioning, planning clock distribution and other structure, methodology), partition/full chip timing closure (primetime scripts, other tools, etc) and gate-level design of high-speed logic RESPONSIBILITIES:
 Chip integration and netlist generation
 Synthesis, Formal verification, netlist quality check
 Work in conjunction with Place and Route Engineers to achieve timing closure for both partition level and full chip level
 Develop and enhance entire timing flow from frontend (pre-layout) to backend (post-layout) at both chip and block level.
&#61623; Develop custom timing scripts using tcl/primetime for clock skew analysis, special circuits such as clock dividers, core logic <-> IO macros interfaces such as PCI-E, Frame-Buffer/Memory, TMDS, etc.
&#61623; Develop flow to physically partition and floorplan the entire chip.
&#61623; Develop scripts for performing ECO's.
MINIMUM REQUIREMENTS:
&#61623; BS or MS in Electrical Engineering or Computer Science
&#61623; Above 3 years of relevant ASIC experience ideally with a focus in the chip integration /synthesis/formal and timing closure
2 | P a g e
&#61623; - Excellent scripts skills
&#61623; - Excellent written and verbal communication skills in English
&#61623; - Ability to multiplex many issues, set priorities, and work in a team environment
&#61623; - Keep up to date with leading edge technologies
GMT+8, 2025-12-19 16:26 , Processed in 0.019348 second(s), 5 queries , Gzip On, Redis On.
