查看: 2576|回复: 4
[求助] hspice仿真问题: model name p in the element 0:mm4 is not defined
发表于 2014-10-17 15:58:52 | 显示全部楼层 |阅读模式
小弟最近做了一下数字电路的hspice仿真,用v2lvs把.v文件转成.sp文件后,用hspice -i xxx.sp -o xxx.lis发现报错哦如下:
**error** model name n in the element     0:mm2
is not defined.
**error** model name p in the element     0:mm4
is not defined.
**error** model name n in the element     0:mm1
is not defined.
**error** model name p in the element     0:mm3
is not defined.
请问有没有人遇到过这种情况?现在就差这一个仿真没做了,马上就要流片了,着急。。。。
 楼主| 发表于 2014-10-17 16:04:27 | 显示全部楼层
我用的sp文件是这样定义库的:
.INCLUDE "/home/LHG/zhangzy/thirdflow/source/hspice/v2lvs_csmc/final1014_afterdfm.sp"
$.option  ba_file='/home/LHG/zhangzy/thirdflow/source/hspice/v2lvs_csmc/IC035os142_typ.spc'
.lib  "/home/LHG/zhangzy/thirdflow/source/hspice/v2lvs_csmc/hm3524mbav211.lib" tt
.lib  "/home/LHG/zhangzy/thirdflow/source/hspice/v2lvs_csmc/hm3524mbav211.lib" diotypical
.lib  "/home/LHG/zhangzy/thirdflow/source/hspice/v2lvs_csmc/hm3524mbav211.lib" restypical
.lib  "/home/LHG/zhangzy/thirdflow/source/hspice/v2lvs_csmc/hm3524mbav211.lib" captypical
请大神指点啊!非常感谢!
 楼主| 发表于 2014-10-17 16:05:03 | 显示全部楼层
spc文件是spef格式的,而之前用的都是hspice格式的,会不会是spef格式hspice不认?
发表于 2014-10-18 08:52:22 | 显示全部楼层
回复 1# dennisi123
   工具说的很清楚啊,你的lib里没有n和p两个模型,打开lib看看怎么定义的pmos和nmos
 楼主| 发表于 2014-10-18 09:58:30 | 显示全部楼层
回复 4# legend03u8z
   lib里没有定义N和P的model,但spc文件里却用了N和P,给foundry跪了
GMT+8, 2025-12-15 06:06 , Processed in 0.015721 second(s), 5 queries , Gzip On, Redis On.
