楼主: year2004
RHEL 7 运行cadence IC5141USR6 OK.
发表于 2015-2-21 04:28:59 | 显示全部楼层
路径不存在
"ftp://ftp.wallawalla.edu/pub/isos/rhel/7.0/rhel-client-7.0-x86_64-dvd.iso"
发表于 2015-2-21 06:14:57 | 显示全部楼层
But MMSIM will not work.IC 5.141 will pull its own spectre simulator, not MMSIM spectre..
I have tried on CentOS 6.6 and it doesn't work..
However IC 5.141 works well even with MMSIM 14 on RHEL 4WS.
Anybody knows why ???
发表于 2015-7-3 10:26:55 | 显示全部楼层
Hi all,
I have same error with YULONGUTK when I install IC5 on rhel 7
"ERROR: can't determine installation root.
can't find tools/bin/cds_root in any parent directory of /opt/eda/cadence/IC5141/tools/dfII/bin/icfb
Unable to find the Cadence software in your $PATH."
Anybody can help?
发表于 2015-7-3 13:01:08 | 显示全部楼层
发表于 2015-7-3 15:02:47 | 显示全部楼层
duo xie fen xiang
发表于 2015-7-14 15:16:28 | 显示全部楼层
我把REAHAT7装好了 ,但现在这个共享文件夹怎么都mont不上,求高手指点
发表于 2015-7-21 17:15:12 | 显示全部楼层
按照ftp://ftp.wallawalla.edu/pub/iso ... -7.0-x86_64-dvd.iso地址,下载rhel7,但需要用户名和密码,求助用户名和密码?
发表于 2015-9-11 18:06:28 | 显示全部楼层
回复 1# year2004
did you add .i686 library?
the RHEL 7 only has 64bit version , if not add some .686 lib it will not work.
Would you like to describe the procedure you install the RHEL7 ( choose which server or steps )?
发表于 2015-10-1 22:47:24 | 显示全部楼层
你应当仔细run几个设计才说的!
发表于 2015-10-1 23:52:53 | 显示全部楼层
單機版?????
GMT+8, 2025-12-18 19:53 , Processed in 0.017311 second(s), 3 queries , Gzip On, Redis On.
