楼主: year2004
RHEL 7 运行cadence IC5141USR6 OK.
 楼主| 发表于 2014-10-16 11:32:52 | 显示全部楼层
回复 10# orwell
    这几天有空,就搭建个环境,测试一下RHEL 7 和 Centos 7 ,系统架构变化比较大。xmanage4、exceed14测试链接有问题。不过vnc没有问题。
发表于 2014-10-16 16:53:10 | 显示全部楼层
 楼主| 发表于 2014-10-16 17:16:46 | 显示全部楼层
回复 12# michaelzhang561
   不客气了。
发表于 2014-10-16 21:34:16 | 显示全部楼层
谢了,LZ.
 楼主| 发表于 2014-10-18 09:15:21 | 显示全部楼层
synopsys2013版测试没有问题.
 楼主| 发表于 2014-10-18 10:11:49 | 显示全部楼层
In RHEL7 how do I enable XDMCP?
Tried the following steps:
Installed GDM packages using command line:
yum install gdm -y
Edited /etc/gdm/custom.conf file and added the foolowing entries:
[xdmcp]
Enable=true
[security]
DisallowTCP=false
AllowRemoteRoot=true
Rebooted RHEL7.
On the X server, tried XDMCP connection to RHEL7 host, got back message: "Oh no! Something has gone wrong. A problem has occurred and the system can't recover. Please log out and try again."
发表于 2014-10-21 11:14:40 | 显示全部楼层
thanks year2004 told us about RHEL7 can run tools properly
 楼主| 发表于 2014-10-21 16:47:49 | 显示全部楼层
    测试情况如何?
发表于 2014-10-22 14:15:16 | 显示全部楼层
回复  michaelzhang561
    测试情况如何?
year2004 发表于 2014-10-21 16:47
    sorry,i am a little busy recently,so i don't install rhel7 on my computer and after finish installing and testing,i will give you a feedback.
发表于 2014-11-3 21:26:11 | 显示全部楼层
回复 9# year2004
你好,安装哪个版本的rhel?
rhel-client-7.0-x86_64-dvd.iso
rhel-server-7.0-x86_64-dvd.iso
rhel-workstation-7.0-x86_64-dvd.iso
GMT+8, 2025-12-18 16:45 , Processed in 0.020866 second(s), 4 queries , Gzip On, Redis On.
