查看: 1057|回复: 0
[招聘] 【全职】Marvell招聘Senior Physical Design Engineer
发表于 2014-9-15 13:59:05 | 显示全部楼层 |阅读模式
Department:Switching R&D
Essentialskills:
MSin EE required.
·Proventrack records of working independently on place-and-routeproject running and DRC/LVS/ERC/Antenna debugging skills
·Experiencewith Magma or Synopsys place-and-route tool set and physical design projectimplementation.
·Goodprogramming skill.
·Capableof writing Tcl or Perl.
·Familiarwith synthesis, static timing analysis.
·Self-motivatedteam worker, good verbal and written communication skills in English.
·Technicaland team leadership proffered. Previous management experience highly desired.
·Experiencewith synthesis, DFT, and verification is preferred.
KeyResponsibilities
Dependingon experience, key responsibilities will involve some of the following:
·ICimplementation from netlist to gdsii, with synthesis, floorplanning, placeand route, timing closure, and physical verification.
·Asa key member of physical design team, your will work on one of most advancedand the most complex chip Marvell designed.
·Leadinga team of physical design engineers and resolving the technical related issues.
·Crosstalkanalysis, power analysis, and static timing analysis.
·Write scripts in Tcl to improveproductivity.
If you have any interest in the position, please send your bilingual resume as attachments to emilyye@marvell.com
Subject of your email should be “Your Name_University_Applied Position Title”
GMT+8, 2025-12-27 00:29 , Processed in 0.014496 second(s), 7 queries , Gzip On, Redis On.
