查看: 26531|回复: 13
[求助] cadence QRC提参遇到的问题,附操作流程和log
发表于 2014-9-13 13:02:23 | 显示全部楼层 |阅读模式
小弟正在尝试calibre LVS+QRC的提参流程,工艺是SMIC 28nm PS,遇到以下两方面问题,求给建议
软件及环境:
1)Redhead 5
2)Cadence IC 6.1
3)Cadence Extraction QRC - Parasitic Extractor - Version 10.1.3-p065
(安装文件用的http://bbs.eetop.cn/thread-355374-1-1.html,patch将就用的IUS 9.2 http://bbs.eetop.cn/thread-268069-1-1.html
4)calibre 2013.3_39.24
一、virtuoso layout XL无法加载QRC UI
按网上说明,在cdsinit文件加入配置,但layout工具栏上仍然看不到QRC的调用按钮。
二、使用命令运行QRC,生成capfile时报错
报错信息
WARNING (LBMISC-215001): file 'via1' is not a flat edge file
ERROR (LBMISC-215002):
it is a hierarchical edge file
做LVS时已选择Flatten
QRC命令行流程:
1. run lvs by GUI with lvs.cmd (fab provided), and make a clean result
2. run lvs by GUI with xrc.cmd (edited from lvs.cmd according to fab‘s guidance).
3. run calibre:calibre -query_input query_cmd -query svdb xrc_test
4. run:qrc -cmd qrc_cmd
qrc_cmd file:
output_setup -temporary_directory_name qrc_output
log_file -file_name qrc_output/qrc.log
process_technology -technology_library_file "qrc_rule/QRC_28PS_1P8M_6Ic_2TMc_ALPA1_V0.5_1T/rulefiles/tech.lib" -technology_name CMAX
input_db -type calibre -directory_name query_output -run_name Design -layer_map_file query_output/Design.gds.map -device_property_value 7 -instance_property_value 6 -net_property_value 5 -library_cell_list_file qrc_rule/assura_QRC/preserveCellList.txt -hierarchy_delimiter \/ -design_cell_name test_qrc av_extracted test_qrc
output_db -type dspf
qrc.log file:
(前面运行内容省略)
# Run pax16 to generate capfile
pax16 -V -scf sip.cmd -M_perim_off -cgnd ${CAP_GROUND},1.0 -c \
/home/yangsy/tmp/28qrc/xrc_test/qrc_rule/QRC_28PS_1P8M_6Ic_2TMc_ALPA1_V0.5_1T/rulefiles/CMAX/qrcTechFile \
-f FOXA active poly metal1 metal2 metal3 metal4 metal5 metal6 metal7 \
metal8 alpa_inter - \
- - NET - capfile
rdpaxcmd took
0.35 user, 0.15 sys, 1.00 elapsed, 47952.0 kbytes
ERROR (LBRCXM-609): Bad return status from RCX run. 0xff00
INFO (LBRCXM-709): *****
QRC terminated abnormally
 楼主| 发表于 2014-9-13 22:04:42 | 显示全部楼层
帖子不要沉啊,自己顶一下。
发表于 2014-9-14 14:59:20 | 显示全部楼层
不懂,你是跑transistor level qrc抽取么?
和calibre starrcxt CCI flow类似,  我只跑过gate level的, trans不太懂,
 楼主| 发表于 2014-9-16 09:26:49 | 显示全部楼层
回复 3# icfbicfb
我不做trans也行,主要是想把长连线的RC跑出来。不知你有什么建议没有?
 楼主| 发表于 2014-9-28 16:59:14 | 显示全部楼层
还是没高手帮忙吗?  谁做过smic 28nm starRC流程的交流下也行
发表于 2014-9-29 22:23:43 | 显示全部楼层
回复 1# yangsy85
   你们够潮流啊     smic 28      的现在就开始了啊
发表于 2015-1-12 15:34:00 | 显示全部楼层
楼主问题解决了没有   我这同样是Smic 28nm PS工艺   QRC是跑出来了  但是其中的via孔全部丢失,导致了M2以及其以上的寄生参数都有问题     求救
发表于 2015-4-17 15:06:44 | 显示全部楼层
只跑某些线的RC的话,可以在inputs里面的include里找到想抽取的线即可,我以前试过,但是跑出来的结果差强人意,你可以看看这个帖子
http://bbs.eetop.cn/thread-475520-1-1.html
发表于 2015-4-17 15:43:26 | 显示全部楼层
普通starxt flow应该行吧,比如抽取milkyway的
发表于 2016-3-1 21:21:45 | 显示全部楼层
回复 1# yangsy85
楼主,你是怎么在cdsinit文件中配置qrc部分的
GMT+8, 2025-12-29 14:02 , Processed in 0.031124 second(s), 6 queries , Gzip On, Redis On.
