查看: 2417|回复: 0
[求助] EPM240驱动LCD1602
发表于 2014-9-12 14:05:05 | 显示全部楼层 |阅读模式
初学verilog,手头正好有EPM240核心板和LCD1602,参考了一些资料尝试着用三段式状态机写得,但通电后LCD没有显示,请大神帮忙看看程序有什么问题,不胜感激。代码如下:
module lcd1602(
clk_50,
rst,
lcd_rs,
lcd_rw,
lcd_en,
lcd_data
input clk_50;
input rst;
output lcd_rs;
output lcd_rw;
output lcd_en;
output [7:0]lcd_data;
reg clk_lcd;
reg lcd_rs;
reg [7:0]lcd_data;
reg [7:0]current_state;
reg [7:0]next_state;
reg [15:0]count;
wire lcd_en;
wire lcd_rw;
/*************状态编码**************/
parameter idle              =8'b0000_0000;
parameter displaymode =8'b0000_0010;
parameter displayoff     =8'b0000_0100;
parameter displayclear  =8'b0000_1000;
parameter displayshift  =8'b0001_0000;
parameter displayon     =8'b0010_0000;
parameter setddram    =8'b0100_0000;
parameter writeram     =8'b1000_0000;
/*************50M分频至500Hz**************/
always@(posedge clk_50)
begin
  if(!rst)
    begin
      count<=0;
      clk_lcd<=0;
    end
  else
  if(count<49999)
    begin
       count<=count+1'b1;
    end
  else
    begin
       count<=0;
       clk_lcd<=~clk_lcd;
    end
end
/****************LCD初始化****************/
assign lcd_en=clk_lcd;
assign lcd_rw=1'b0;
always@(posedge clk_lcd or negedge rst)
begin
  if(!rst)
    current_state<=idle;
  else
    current_state<=next_state;
end
always@(*)
begin
    case(current_state)
    idle              :next_state=displaymode;
    displaymode :next_state=displayoff;
    displayoff     :next_state=displayclear;
    displayclear   :next_state=displayshift;
    displayshift   :next_state=displayon;
    displayon     :next_state=setddram;
    setddram     :next_state=writeram;
    writeram      :next_state=setddram;
    default         :next_state=idle;
    endcase
end
begin
  if(!rst)
     begin
        lcd_rs<=0;
        lcd_data<=8'bzzzz_zzzz;
     end
  else
    begin
       case(next_state)
       idle              : lcd_rs<=0;
       displaymode : lcd_rs<=0;
       displayoff     : lcd_rs<=0;
       displayclear  : lcd_rs<=0;
       displayshift   : lcd_rs<=0;
       displayon     : lcd_rs<=0;
       setddram     : lcd_rs<=0;
       writeram      : lcd_rs<=1;
       default        : lcd_rs<=0;
       endcase
       case(next_state)
       idle              : lcd_data<=8'bzzzz_zzzz;
       displaymode : lcd_data<=8'b0011_1000;//38h,显示模式设置
       displayoff     : lcd_data<=8'b0000_1000;//08h,显示关闭
       displayclear  : lcd_data<=8'b0000_0001;//01h,显示清屏
       displayshift  : lcd_data<=8'b0000_0110;//06h,显示光标移动设置
       displayon     : lcd_data<=8'b0000_1100;//0ch,显示开及光标设置
       setddram     : lcd_data<=8'b1000_0000;//设置第一行第一个地址
       writeram      : lcd_data<="A";//显示字符"A"
       endcase
    end
end
endmodule
GMT+8, 2025-12-19 00:34 , Processed in 0.014248 second(s), 7 queries , Gzip On, Redis On.
