查看: 2225|回复: 0
[求助] hspice仿真问题:Number of nodes miss match between instance
发表于 2014-9-1 11:03:32 | 显示全部楼层 |阅读模式
今天做hspice仿真,遇到一个 **error** (example5.sp:19216) :Number of nodes miss match between "xinvbd2_g1b1i550" and subcircuit "inv0d4".  Subcircuit definition has    2 node(s) whereas subckt instance was found with    0 node(s). Please specify same number of nodes.
我的sp网表第19216行如下:
Xinvbd2_G1B1I550 inv0d4 $PINS I=clk_cts_0_33 ZN=CLK_G1B30I550
在sp网表里也定义了inv0d4的SUBCKT:
.SUBCKT inv0d4  ZN   I
M1      ZN      I       VSS     VSS     nmos_3p3 L=0.35U  W=13.40U
M2      ZN      I       VDD     VDD     pmos_3p3 L=0.36U  W=14.56U
.ENDS inv0d4
这两个都有两个node,而且inv0d4在之前的行里也有实例化,都不报错,为什么这一行会遇到问题呢?求高人指点!非常感谢!
GMT+8, 2025-12-18 15:12 , Processed in 0.012011 second(s), 3 queries , Gzip On, Redis On.
