查看: 5832|回复: 7
在做邦定图时,怎样得到版图中的PIN角的坐标,尤其是数字区与模拟区是用PIN连的时候。
发表于 2014-8-28 15:00:12 | 显示全部楼层 |阅读模式
(hiSetBindKey "Layout" "<Key>F10" "textViewCoord()")
(procedure (textViewCoord)
(prog (cw cv selobjects selobj  LabelName points)
(setq cw (hiGetCurrentWindow))
(setq cv (geGetEditCellView))
(setq selobjects (geGetSelSet cv))
(setq myPort  (outfile "/home/wangy/TEST_PROC/TxetCoordinate.txt"))
(fprintf myPort "pinName     x            y\n" )
(foreach selobj selobjects
(setq points0 selobj->objType)
(if (equal selobj->objType "label")  then
(setq LabelName selobj->theLabel)
(setq points selobj->xy)
(setq xCoordx (xCoord points))
(setq yCoordy (yCoord points))
(fprintf myPort "%5s    %f    %f\n" LabelName xCoordx yCoordy)
);endif
);foreach
(close myPort)
);prog
);proce
这是得到的效果图,全选中所有元素,只得到PIN的坐标。
这是在LINUX中的文件COPY到记事本中,再到EXCEL中打开就得了想要的结果
 楼主| 发表于 2014-8-28 18:12:14 | 显示全部楼层
回复 1# wangyan2059
秀秀小东西解决大问题的SKILL。谁能再改成一个PIN打歪了修正到NET或PAD中心后,再输出来坐标的SKILL,呵呵。
 楼主| 发表于 2014-9-25 18:09:20 | 显示全部楼层
(prog (cw cv selobjects selobj  rang  width  number LabelName points x1 y1 x2 y2 offsetX offsetY)
(setq rang 2)
(if (nequal selobj->objType "label")  then
(geDeselectFig selobj))
);foreach
(foreach selobjL selobjects
(if (equal selobjL->objType "label")  then
(setq LabelName selobjL->theLabel)
(setq layerLabel selobjL~>layerName)
(setq points selobjL~>xy)
(setq objects (gePointToFig (hiGetCurrentWindow) nil points))
(if (and (equal objects~>layerName layerLabel) (equal objects~>objType "path")) then
    (setq points  objects~>path)
    (setq width (quotient objects~>width 2))
    (setq number (difference objects~>nPoints 2))
(for number 0 number
(if (or (lessp (abs (difference yCoordy (yCoord (nth number points)))) width) (lessp (abs (difference xCoordx (xCoord (nth number points)))) width)) then
(setq x1 (abs (difference (xCoord (nth number+1 points)) (xCoord (nth number points))) ) )
(setq y1 (abs (difference (yCoord (nth number+1 points)) (yCoord (nth number points))) ) )
(if (greaterp x1 0.0001) then
(setq offsetY (difference (yCoord (nth number points)) yCoordy) )
else
(setq offsetY 0))
(if (greaterp y1 0.0001) then
(setq offsetX (difference (xCoord (nth number points)) xCoordx) )
else
(setq offsetX 0))
);endif
(postincrement number));endfor
);endif
(if (and (equal objects~>layerName layerLabel) (equal objects~>objType "rect")) then
(setq Box objects~>bBox)
(setq x2 (plus (abs (quotient (difference (xCoord (lowerLeft Box)) (xCoord (upperRight Box))) 2)) (xCoord (lowerLeft Box))) )
(setq y2 (plus (abs (quotient (difference (yCoord (lowerLeft Box)) (yCoord (upperRight Box))) 2)) (yCoord (lowerLeft Box))) )
(if (lessp (abs (difference xCoordx x2)) rang) then
(setq offsetX (difference x2 xCoordx)))
(if (lessp (abs (difference yCoordy y2)) rang) then
(setq offsetY (difference y2 yCoordy)))
);endif
(setq movePare (list (offsetXffsetY) "R0"))
(dbMoveFig selobjL, nil, movePare)
(fprintf myPort "%5s    %.3f    %.3f\n" LabelName xCoordx yCoordy)
);endif
);foreach
(close myPort)
);prog
);proce
注意情况.zip
474 Bytes, 下载次数: 30 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2014-9-25 18:20:26 | 显示全部楼层
回复 3# wangyan2059
上面的是已改成一个PIN打歪了修正到NET或PAD中心后,再输出的SKILL。谁把这个修改成也能输出层次化单元的PAD中心坐标啊?
发表于 2014-9-26 14:42:30 | 显示全部楼层
嗯,能说说这个具体使用的场合吗?
回复 4# wangyan2059
发表于 2015-12-30 13:48:37 | 显示全部楼层
来学习下
发表于 2017-5-10 19:07:44 | 显示全部楼层
同学习下
发表于 2019-10-28 10:39:25 | 显示全部楼层
谢谢!!!!
GMT+8, 2025-12-21 07:10 , Processed in 0.029394 second(s), 7 queries , Gzip On, Redis On.
