楼主: min4max
从Cadence官方网站下载安装Cadence所有软件!
发表于 2016-4-2 22:34:18 | 显示全部楼层
回复 1# min4max
Effective 9-Nov-2015, the access policy for software downloads has changed. Access is only available for our users registered with our support or B2B portals. If you are only registered on cadence.com you may not have access to our software downloads.
发表于 2016-4-7 16:57:14 | 显示全部楼层
回复 171# kaikanertan
   所以怎么办,下载不了了现在
发表于 2016-4-7 16:58:10 | 显示全部楼层
回复 171# kaikanertan
   楼主能分享几个已经下载好的比如IC 616的安装包么
发表于 2016-4-25 08:09:29 | 显示全部楼层
感谢楼主为大家着想
发表于 2016-4-28 10:13:55 | 显示全部楼层
QQ图片20160428102054.png 有个问题想请教大牛,安装完BASE以后接着安装IC06.16.080 HOTFIX 时,提示我: to complete installing this release ,you must specify the follwing media:  IC 06.16.080 RHEL 5(lnx86) Hotfix Release Disk 1?
发表于 2016-4-30 01:54:41 | 显示全部楼层
thanks a lot
发表于 2016-4-30 13:16:53 | 显示全部楼层
thanks
发表于 2016-4-30 23:08:32 | 显示全部楼层
thank you
发表于 2016-5-8 23:17:42 | 显示全部楼层
谢谢!
发表于 2016-5-19 21:21:36 | 显示全部楼层
appreciated
GMT+8, 2025-12-28 14:18 , Processed in 0.021055 second(s), 4 queries , Gzip On, Redis On.
