查看: 1900|回复: 1
[招聘] AMD上海研发中心热招职位列表
发表于 2014-8-8 15:29:11 | 显示全部楼层 |阅读模式
AMD上海研发中心热招以下职位,请感兴趣的把简历发送至
maggie1.zhang@amd.com,
并注明所应聘职位,谢谢。欢迎你的加入!
1.
SMTS graphics IP low power design and verification engineer
Job Responsibilities:
In this key role, the candidate will be responsible for low power implementation and verification of Graphics hardware
  • Development of infrastructure for verification of hardware in GFX IP.
  • Develop low power verification environments for feature test, and use the automated regression infrastructure setup for IP level and IP on SoC level functional verification.
  • Low power design and verification for specific hardware functionality in Front-end.
  • Improve the low power IP delivery for variant SoCs
Education& Qualifications:
1.
BS, MS or PhD in Electrical Engineering or Computer Science.
2.
10+ years of ASIC verification or low power design/verification experience
3.
UPF based low power design/verification or computer graphics knowledge are plus
4.
Should have good understanding of Pre-Silicon design process from Architecture, Design, Synthesis and Gate level Implementation till tapeout release.
5.
Advanced programming knowledge on Verilog/SystemVerilog, C/C++
6.
Requires demonstrated technical expertise in the areas of low power design/verification methodology.
7.
Knowledge on Perforce, OVL, SVA, SV, UVM, script programming etc.
8.
Should have excellent communication skills (both written and oral) and should be able to participate cross functional engineering teams geographically.
2.
Senior ASIC CAD engineer
Position Summary
Participate in the design and implementation of the leading edge, front-end ASIC design flow
Participate in the research of Design Methodology to improve automation and  productivity to produce AMD's new high-quality cutting-edge APU and GPU products
Technical support and programming
Interface with EDA vendors on technology
Essential Requirements/Qualifications:
Major in EE, CS or related, Master Degree with 3+ years or Bachelor with 5+ years working experience
Experience in Front-end digital design and VerilogHDL is required
Good programming skill with one or more languages (e.g. Tcl, Perl , python, c/c++, etc.) in Unix/Linux and a strong desire to automate flow
Familiar with one or more ASIC flows (logic synthesis, formal equivalence check, STA etc.) and usage of related EDA tools is a plus
Familiar with low power design is a plus
Good written and spoken English
Good communication skills and be able to work both independently and in a team
3.
MTS Design Verification Engineer for Graphics Hardware (IP Level)(required candidate with solid 3D or openGL software background.)
Key Job Functions:
- Understand the chip architecture or algorithm for 3D Graphics
- Compose test plan and validation vectors to ensure functional completeness
- Develop tests for IP level and full chip functional verification.
- Help debug and correct functional errors in the design blocks, using logic abstraction, simulation and debug tools, based on good understanding of the architectural specification, RTL and/or device level design of the block and protocols between the blocks.
- Closely working with multiple BLK Design/Architecture/block DV team to identify the Milestones and Quality metrics of the project that includes scoping, tracking and delivery.
- Be responsible to mentor and coach the team for greater technical depth in Functional areas as well as the verification methodology improvement and Infrastructure enhancements to support the design environment
Preferred Experience:
- Major in EE, CS or related, Master Degree with 5+ years or Bachelor with 7+ years working experiences
- Versatile in computer architecture or 3D Graphics HW or 3D Algorithm
- Advanced programming knowledge on C++;
Programming knowledge in OpenGL, DirectX, OpenCL is optional
- Good understanding of Verification methodology and concepts
- Strong communication skills (both written and oral) and should be able to participate cross functional engineering teams geographically.
- Familiar with Linux Environment (including shell scripting and linux gnu tools)
- Strong problem solving skills
发表于 2014-8-8 16:33:24 | 显示全部楼层
北京的环境还是不太好啊,坑儿都在上海了
GMT+8, 2025-9-16 09:22 , Processed in 0.016399 second(s), 6 queries , Gzip On, Redis On.
