查看: 1545|回复: 0
[招聘] 【Marvell】招聘Silicon Validation/Application Engineer
发表于 2014-8-4 11:33:57 | 显示全部楼层 |阅读模式
Job Title: SiliconValidation Engineer
Qualifications:
M.S.E.E + 2 years experience. Experienceworking in an IC testing environment with equipment such as Oscilloscopes andAWG's is desired but not required. Proficiency with Matlab or Python is desiredbut not required. Direct experience with Read Channels and hard disk drives isdesired, but not required.
Department profile: Silicon ValidationEngineering group for Read Channels is responsible for validating all readchannel devices designed by Marvell. The activities also include performancemeasurement and automation of the tools used for validating the read channel.The group is also responsible for the hardware and software design of all toolsrequired for the above two activities.
Responsibility:
- Design and execute system level tests forcomplex mixed signal ICs using standard test equipment such as Oscilloscopes,network analyzers, etc.
- Work with designers to debug, understandand document new designs.
- Provide technical documentation,descriptions and information to Field Application Engineers, Test Engineers andcustomers.
- Write and maintain software used toautomate bench testing. This is done in the MATLAB environment for now; maymove to other tools in future.
- Generate professional validation reportsand comparative performance analysis of the read channel devices.
- Work with DSP and design teams to find thebest optimization procedures for Marvell read channel products.
- Make sure we can showcase the best read channelperformance on customer drives.
If you have any interest in the position, please send your bilingual resume as attachments to emilyye@marvell.comSubject of your email should be “Your Name_University_Applied Position Title
GMT+8, 2025-12-29 00:33 , Processed in 0.043400 second(s), 5 queries , Gzip On, Redis On.
