查看: 3667|回复: 1
[资料] msp430f5529的一个程序。。。
发表于 2014-7-31 16:36:38 | 显示全部楼层 |阅读模式
#include <msp430.h>
#define unchar unsigned char
#define uint unsigned int
uint date;
                                                      //定义数据类型
uint dispcount=0;
                                                   //中断计数
unchar times=0;
                                                 //定时器计数
uint disp=0;
                                                        //频率值
unchar str[3];
unchar *s;
#define CS        P2DIR |= BIT2
#define CS_H      P2OUT |= BIT2
#define CS_L      P2OUT &= ~BIT2
#define SID       P2DIR |= BIT3
#define SID_H     P2OUT |= BIT3
#define SID_L     P2OUT &= ~BIT3
#define SCLK      P2DIR |= BIT4
#define SCLK_H    P2OUT |= BIT4
#define SCLK_L    P2OUT &= ~BIT4
#define RST       P2OUT |= BIT5
#define RST_H     P2OUT |= BIT5
#define RST_L     P2OUT &= ~BIT5
void delay( uint t);
void sendbyte( unchar z);
void write_com( unchar cmd);
void write_data(unchar disp);
void init_lcd();
void diszfc( unchar *s);
void lcd_clear();
unchar * int2str(uint d);
void gotoxy(uint x,uint y)
void red() ;
void green() ;
void blue()
void init_clk();
void main(void)
    WDTCTL = WDTPW | WDTHOLD;
// Stop watchdog timer
    init_clk();
    P1DIR |= BIT3 + BIT4 + BIT5 + BIT6;
    TACTL = TASSEL_1 + ID0 + TACLR;//ACL = 32768 ,2分频
    CCTL0 = CCIE;
CCR0 = 819;//819 * 2 / 32768 =50ms
TACTL |= MC0; //增计数
    P1DIR &= ~BIT2;
    P1SEL |= BIT2;
    TACCTL1 |= CM_2 + SCS + CAP + CCIE;//捕获模式,同步捕获,中断打开,下降沿捕获
    _EINT();
    __bis_SR_register(LPM3_bits);
    delay(200);
init_lcd();
lcd_clear();
while(1)
   gotoxy(1,00); diszfc("R:"); red();
//调用红色通道并显示色彩值
       gotoxy(1,02);
s = int2str(date);      diszfc(s);
       gotoxy(1,05); diszfc("  ");
       gotoxy(1,07); diszfc("G:"); green();//调用绿色通道并显示色彩值
       gotoxy(1,011);   s = int2str(date);       diszfc(s);
       gotoxy(1,014); diszfc("  ");
       gotoxy(2,00);  diszfc("B:"); blue();
//调用蓝色通道并显示色彩值
       gotoxy(2,02);    s = int2str(date);         diszfc(s);
       gotoxy(2,05);  diszfc("  ");
#pragma vector =TIMERA0_VECTOR
__interrupt void TimerA0(void)
times ++;
if(times == 20)
    disp = dispcount;
times = 0;
dispcount = 0;
#pragma vector =TIMERA1_VECTOR
__interrupt void  TimerA1_ISR(void)
switch(TAIV)                              //向量查询
  { case 2:  dispcount ++;                              //捕获中断
  CCIFG1 = 0;
  break;
  default:    break;
void delay( uint t)
uint i , j ;
for(i = 0; i < t ;i ++)
for (j = 0; j < 10; j++);
void init_clk()//时钟初始化
   unchar i;
   BCSCTL1 = 0X86 ; // XT2OFF , XTS = 0
   do
     IFG1 &= ~OFIFG;//清振荡器失效标志
     for(i=0xff;i>0;i--);
   }while((IFG1 & OFIFG)!=0);//若振荡器失效标志有效
   BCSCTL2 = 0X00 ; // MCLK = DCOCLK, DIVM = 0,SMCLK = DCOCLK,DIVS = 0
* RGB三种颜色通道选择模块
void red()                                                          //红色通道
P1OUT |= BIT3; delay(1100);
date=disp/100;date=(255.0/153)*date;
    //153是在纯白情况下测得的红色通道频率值
void green()                                                       //绿色通道
P1OUT |=BIT3 + BIT5 + BIT6; delay(1100);
date=disp/100;date=(255.0/145)*date;
    //145是在纯白情况下测得的绿色通道频率值
void blue()
                                                    //蓝色通道
P1OUT |= BIT3 + BIT6; delay(1100);
date=disp/100;date=(255.0/183)*date;
    //183是在纯白情况下测得的蓝色通道频率值
         整型数转化成字符串,以便LCD输出显示
if(d>=255)
{ d=255;
str[0]='0'+d/100;
str[1]='0'+d%100/10;
      str[2]='0'+d%10;
else
{ str[0]='0'+d/100;
      str[2]='0'+d%10; }
return str;
                LCD显示模块
void init_lcd()                                                // 初始化lcd
RST_L; //前提是复位脚接P1.5口
delay(100);
RST_H;
P2DIR |= BIT6;
P2OUT &= ~(BIT6);
write_com(0x30);                               // lcd为两行显示8位数据线有效
    write_com(0x0e);                              // 显示字符  关闭光标  0000 0111
    write_com(0x06);                             // 输入方式设置 光标向右移动一位 ac-1
uint i;
for(i = 0; i < 8; i ++)
if ((z<<i) & 0x80)
SID_H;
else
SID_L;
SCLK_L;
SCLK_H;
void write_com( unchar cmd)  //写串口指令
CS_H;
sendbyte (0xf8);  //输指令
sendbyte (cmd & 0xf0);
sendbyte ((cmd << 4) & 0xf0);
delay(2);
void write_data(unchar disp)  //写数据
CS_H;
sendbyte(0xfa);//传数据
sendbyte(disp & 0xf0);
sendbyte((disp << 4) & 0xf0);
delay(2);
void diszfc( unchar *s)   //显示字符串
while ( *s > 0)
write_data(*s);
s++;
delay(50);
void lcd_clear()
write_com(0x01); //清屏指令
write_com(0x02); //光标归位 即光标置于左上位置
                      //定位  ,x为行,y为列
if(x==1)
write_com(0x80+y);
   else
    write_com(0xC0+y);
哪位大神能帮忙看看啊。。。
 楼主| 发表于 2014-7-31 16:44:38 | 显示全部楼层
第一个error 是在
这后面,说是少了';'
第二个error是在最后,说是少了‘’}‘’
第三个error不懂什么意思。。
GMT+8, 2025-10-25 06:58 , Processed in 0.025767 second(s), 8 queries , Gzip On, Redis On.
