查看: 6646|回复: 13
[讨论] Technology-File
发表于 2014-7-25 06:42:12 | 显示全部楼层 |阅读模式
could anyone please  tell me how i can get technology file from cadence to use it in Sonnet or Momentum or Asitic i'm using tsmc130nm
i don't find stack layers in PDK Documents
thanks in advance
 楼主| 发表于 2014-7-25 09:16:14 | 显示全部楼层
any help please
发表于 2014-7-25 09:44:59 | 显示全部楼层
回复 2# Islam2014
go to PDK files, if you have assura extraction files, you can find layer stack information in pl2lvs(something like that).if you have calibre files, go to calibre extraction rules file.
 楼主| 发表于 2014-7-25 19:53:14 | 显示全部楼层
Reply 3 # podcast
thanks for help i found this file in Assura Extraction Files could you please tell me how to use it in Sonnet or momentum
    p2lvsfile.rar (401 Bytes , 下载次数: 38 )
发表于 2014-7-25 23:26:46 | 显示全部楼层
回复 4# Islam2014
This file contains properties of metal layers. As for thickness of each layer, and properties of dielectrics, youneed to refer to the file named procfile. With the information of those two files, you can make a substrate file
manually. That's very tedious, and error-prone. Good luck!
 楼主| 发表于 2014-7-26 02:00:30 | 显示全部楼层
回复 5# podcast
   thanks for your help really appreciate that
发表于 2014-10-14 18:11:30 | 显示全部楼层
回复 6# Islam2014
    use sonnet virtuoso integrate that convert assura proc to sonnet mat
also you can use goldengate to convert assura files to momentum tech
发表于 2016-4-24 12:02:46 | 显示全部楼层
哈哈哈哈 楼上的podcast和Islam 你俩够啦 一个Ali 一个Rabaey,哈哈哈哈哈
发表于 2016-4-24 13:47:43 | 显示全部楼层
楼主辛苦
发表于 2016-4-24 13:50:41 | 显示全部楼层
楼主辛苦
GMT+8, 2025-9-19 05:33 , Processed in 0.372764 second(s), 7 queries , Gzip On, Redis On.
