查看: 9815|回复: 11
最新Cadence SPB16.6 Hotfix S031下载
发表于 2014-7-22 09:39:54 | 显示全部楼层 |阅读模式
DATE: 06-20-2014   HOTFIX VERSION: 031
CCRID  PRODUCT        PRODUCTLEVEL2   TITLE
726553  FSP            CAPTURE_SCHEMATI Method to select bus bit?s order while generating Capture design from FSP.
1257631 FSP            DE-HDL_SCHEMATIC SchematicGeneration selects incorrect symbol version
1273456 ALLEGRO_EDITOR PLACEMENT        Place module instance causes Allegro tocrash
1277099 ALLEGRO_EDITOR INTERACTIV       Clines and pins are disconnected eventhough they are at the same x, y coordinate.
1280913 ALLEGRO_EDITOR EDIT_ETCH        Add Connect should be able to be madeby go straight even though the cursor is not exist on straight line
1282491 ADW            PURGE            ADW PURGE is removing Page Name datain DEHDL
1283045 ALLEGRO_EDITOR DATABASE         Ecset not getting downreved.
1283138 SIP_LAYOUT     IC_IO_EDITING    symed app mode chooses wrong text blocksizes for I/O driver inst names
1283227 PDN_ANALYSIS   PCB_STATICIRDROP Enhancement request to add32 bit files for IRdrop
1284656 CONCEPT_HDL    CREFER           Crefer fails on large design
1285814 CONCEPT_HDL    CORE             DEHDL crash on opening the Design
1285967 ALLEGRO_EDITOR EDIT_ETCH        Slide via in circle pad ===================================================
下载地址:http://pan.baidu.com/s/1eQpamRo
发表于 2014-8-29 23:36:16 | 显示全部楼层
下下来看看能不能用
发表于 2014-8-30 04:19:45 | 显示全部楼层
DATE: 08-22-2014   HOTFIX VERSION: 034
932528  CONCEPT_HDL    OTHER            Ability to handle reusemodule in soft reuse blocks.
1137838 FSP            GUI              Ability to add notes to the canvas
1274382 ALLEGRO_EDITOR OTHER            Retaining rats at the end of the clines or vias
1283575 FSP            DE-HDL_SCHEMATIC Force Schegen to use symbols from released library
1296331 CONCEPT_HDL    COMP_BROWSER     CSV export no longer works properly from Component Browser
1297855 F2B            DESIGNSYNC       ds -automode error
1298028 CONCEPT_HDL    CREFER           CreferHDL crashes
1299607 SIG_INTEGRITY  OTHER            AutoModel should generate ESpice models for illegal values
1299609 CONCEPT_HDL    OTHER            AutoModel should make an ESpice model for a 3 pin Capacitor
1302013 ALLEGRO_EDITOR EDIT_ETCH        AiBT Crashes Allegro for nets having T points
1302209 SPIF           OTHER            Can't Export to Router and create a Specctra file.
1302242 F2B            PACKAGERXL       Packaging a hierarchical project does not create a full pstdmodeldat file
1302285 SCM            CONN_SERVER      DSCS-120: Failed to open file <filename.xcon> in write mode
1302310 ALLEGRO_EDITOR INTERFACES       Need way to have user defined license packages win over Cadence products.
1302638 F2B            PACKAGERXL       Function swaps are not backannotated into the schematic
1303170 SIP_LAYOUT     DIE_STACK_EDITOR Using Die Properties to move a die to the bottom side causes some entities to disacociate from the part
1303214 CONCEPT_HDL    CORE             DEHDL crashes
1303219 ALLEGRO_EDITOR COLOR            The user preference variable color_dlg_auto_apply changes the colors in the Display category
1303685 CONCEPT_HDL    CORE             DEHDL crashes when I save page 3
1303897 CONCEPT_HDL    CORE             Tool crashes intermittently when editing top-level schematic
1304656 APD            PLATING_BAR      Add Plating Bar command convert the Clines having Arcs to 45 Degree segments
1306467 CONCEPT_HDL    CORE             Concepthdl crashes during model assignmnt
DATE: 08-7-2014    HOTFIX VERSION: 033
1265152 CONSTRAINT_MGR OTHER            In CM, for a new worksheet, the Actuals are not seen for Class-Class Objects.
1269155 CONSTRAINT_MGR INTERACTIV       Constraint manager does not evaluate the formulas if the min value is more than the max value
1279589 APD            NC               Duplicated Drills
1280288 CONSTRAINT_MGR OTHER            The option "rename existing refdes" is hidden while doing File>import>logic
1285122 CONSTRAINT_MGR UI_FORMS         Analysis Settings does not appear in constraint Manager Sigrity SI
1291054 CONCEPT_HDL    ARCHIVER         archiver fails to create the cds.lib & cpm files when the -views switch is used in the command line
1291186 SIP_LAYOUT     DXF_IF           Export DXF is incorrectly exporting the top layer pins when they aren?t specified in the output.
1292595 CONSTRAINT_MGR SCHEM_FTB        Revision number reset in dcf when running Import Physical
1293346 ALLEGRO_EDITOR GRAPHICS         smd symbols with Step model not correctly shown in 3D Viewer
1293579 ADW            PCBCACHE         ERROR(SPCOCD-553): Connectivity Server Error: Failed to load component cell 'ti_template.ets600_pogp_143p:sym_1'
1293733 SIG_EXPLORER   EXTRACTTOP       SigXP extraction: Bad memory usage in logicalop Head! message is output on Linux
1293911 ALLEGRO_EDITOR EDIT_ETCH        Using AiPT on this design causes an unrelated via to be deleted
1296433 CONCEPT_HDL    CORE             DEHDL crashes when saving hierarchy
1296735 ALLEGRO_EDITOR NC               Customer want to know why we change the description in SPB166, it causes CAM350 can`t import drill file.
1296743 APD            DEGASSING        Degassing creates wrong voids for second and subsequent shapes when multiple shapes are selected
1296803 ALLEGRO_EDITOR OTHER            Can no longer access some drawing subclasses in 16.6
1298421 ADW            LRM              Artesyn: LRM cannot update the part.
1299871 APD            WIREBOND         The axlSetAllProfilesVisible return all "nill"
1300186 ALLEGRO_EDITOR DATABASE         Deleted NetGroups in DEHDL appear in the Allegro PCB CM
1300961 CONSTRAINT_MGR CONCEPT_HDL      cmdfeedback.exe crashes during import physical
1301180 ALLEGRO_EDITOR GRAPHICS         3D Viewer for SMD footprint shows top pads on bottom layer and place bound wrongly
DATE: 07-25-2014   HOTFIX VERSION: 032
381127  SPECCTRA       CROSSTALK        Specctra xtalk reports aren't correct
616770  ALLEGRO_EDITOR COLOR            Remove the APPLY button in the Color Dialog window.
982944  ALLEGRO_EDITOR COLOR            seperate the Etch to the Shape and the the Cline in the visibility window
982995  ALLEGRO_EDITOR INTERACTIV       Shown infomation for the selected physical symbols
1024832 PSPICE         PROBE            Shows wrong data & header when exporting trace to .txt
1063258 PSPICE         AA_OPT           curve fit fails with error  same data works in 16.5 Simulation error: out of range of data
1112360 PSPICE         AA_OPT           Advacne analysis gives runtime error while using Optimizer in attached design
1154323 PCB_LIBRARIAN  VERIFICATION     Con2con is choosing incorrect Primitive from Chips file and failing FTB Checks
1184690 CONCEPT_HDL    CORE             Weird behavior of genview for split hierarchical blocks
1212577 PSPICE         MODELEDITOR      IBIS translation fails without any information in log file
1213204 ALLEGRO_EDITOR PLACEMENT        Place Manually with existing fixed net behaving incorrectly
1213837 ALLEGRO_EDITOR INTERACTIV       When copying a stacked via the temp highlight does not display on the last layer of the stack.
1216519 SPECCTRA       ROUTE            Autorouter will not add BB via between uvia within the BGA area
1220655 PSPICE         DEHDL_NETLISTER  Support for automatic addition for Power source and Ground Node for Globals  in DEHDL PSpice netlisting
1223018 CAPTURE        OTHER            Diff pair Auto Setup not working for the buses.
1225689 PSPICE         AA_SMOKE         Smoke analysis crashes with attached testcase
1232124 CONCEPT_HDL    COMP_BROWSER     unable to generate ppt_options.dat file in first go
1235059 PCB_LIBRARIAN  IMPORT_CSV       pin_delays not being imported into PDV
1238815 CAPTURE        OTHER            Capture doesn?t retain more than 191 library in add part/capture.ini under part selector configured libraries
1239241 ALLEGRO_EDITOR INTERACTIV       Via replacement doesn't replace with correct via but right padstack name.
1240201 ALLEGRO_EDITOR EDIT_ETCH        RPD DRC unresolved evenif HUD turns Green
1240314 PSPICE         SIMULATOR        Getting internal error,overflow for the second run
1242805 ALLEGRO_EDITOR DRC_CONSTR       no_drc_progress_meter variable hangs allegro after running update drc
1243267 ADW            TDA              URL to TDO-SharePoint should be defined in CPM File
1244857 ADW            TDA              Policy File Variables not working correctly in policy file
1245779 CONCEPT_HDL    CONSTRAINT_MGR   Obsolete objects in DEHDL CM
1246811 CIS            EXPLORER         Option to keep the part type tree in CIS explorer expanded on every invoke
1246964 PSPICE         PROBE            Simulation Crashes in 16.6 but running successfully in 16.5
1248782 CONCEPT_HDL    CORE             Display winning physical bus names (occurrence mode) in the the lower block of an Hierarchical design
1249238 CONCEPT_HDL    CORE             Uprev from 16.3 splatters text around sch page
1249692 ALLEGRO_EDITOR GRAPHICS         3D Viewer is wrong when resizing its window.
1249850 ALLEGRO_EDITOR SHAPE            With shape_rki_autoclip Route Keepin to Shape DRC is created
1250683 ALLEGRO_EDITOR INTERACTIV       devpath corrupts if edited from user preferences.
1252059 ALLEGRO_EDITOR INTERACTIV       Preference Editor is unable to delete a previous path entry for library paths
1253563 SIP_LAYOUT     DEGASSING        Not getting degassing voids when close to shape in center of design
1254319 ALLEGRO_EDITOR GRAPHICS         ENH: Functionality to change the 3D Model color for more realistic view
1254562 ALLEGRO_EDITOR DATABASE         Unable to delete a subclass that exist only on classes Package Keepout, Package Keepin and Route Keepin.
1255169 CONCEPT_HDL    OTHER            ADW (BPc) Packager should report the specific corrupt directive in the .cpm file
1255573 ALLEGRO_EDITOR DRC_CONSTR       Need soldermask DRC checks when same net via and smd pad overlaps
1257950 CONSTRAINT_MGR SCHEM_FTB        Changing xnet name on Allegro CM.
1258165 F2B            DESIGNVARI       changing visibility of Probe_number in variant schematic changes it to $Porbe_number
1258274 PCB_LIBRARIAN  VERIFICATION     con2con crash with no notification or error message
1258860 CAPTURE        PROJECT_MANAGER  Bug: Text Editor (File> New> VHDL File) filters characters from Text
1258872 CONCEPT_HDL    CORE             Objects are copied (instead of moved) when moved from sheet to sheet
1259284 CONCEPT_HDL    PDF              HDL_POWER ( global) net does not get transferred to the published pdf
1259375 CONCEPT_HDL    CORE             Help link to cdnUsers.org needs to be changed
1259860 ALLEGRO_EDITOR INTERACTIV       Edit > Mirror does not display asymmetrical pad correctly when the footprint is attached to cursor.
1260002 ALLEGRO_EDITOR INTERACTIV       Alt sym hard is not obeyed when using Edit > Move > Mirror
1260006 ALLEGRO_EDITOR PLACEMENT        funckey r iange 90 rotation issue
1260667 ALLEGRO_EDITOR EDIT_ETCH        Allegro crashes when running AICC command on few Diff Pair traces.
1260763 CONCEPT_HDL    CORE             Export Physical fails with $TEMP entry in Setup-Tools
1260847 SIP_LAYOUT     SYMB_EDIT_APPMOD Border texts seen as triangles.
1260948 ALLEGRO_EDITOR SHAPE            Dynamic ground shape is shorting to via of a different net at layer 4 & 5 in this design
1262011 ALLEGRO_EDITOR PLACEMENT        Key Properties on Component Instance/ Definition on available to use with Quickplace by Property
1262322 ALLEGRO_EDITOR PADS_IN          Pads_in can not translate route keepout which specified for the all layers.
1262626 CONCEPT_HDL    CORE             PROBE NUMBER attributes lost from the nets after upreving the design
1263592 PCB_LIBRARIAN  VERIFICATION     Unable to check in Schematic Model due to pc.db file
1263685 ALLEGRO_EDITOR INTERACTIV       Editing Photo Width value from non zero to zero allegro gives warning- Value must be greater or greater to zero
1263704 ALLEGRO_EDITOR EDIT_ETCH        Bug - AiTR wrongly deletes blind vias and do reroutes.
1265120 ALLEGRO_EDITOR SHAPE            Require voids in dynamic shapes to use pad value
1265275 ALLEGRO_EDITOR DRC_TIMING_CHK   When XNETS are dissolved by removing the Models all Physical and Spacing NetClass associations are lost
1265633 PSPICE         SIMULATOR        Bias point result is different in consecutive simulation run of the attached project
1266349 ALLEGRO_EDITOR PLACEMENT        Rotating symbol while placement show wrong angle of rotation than the placed angle when Angle is set in Design Parameter
1267541 PSPICE         PROBE            pspice.exe does not exit when run from command line
1267707 ALLEGRO_EDITOR PLACEMENT        Mirror Command - preselect/postselect bug with general edit mode
1268299 PSPICE         STABILITY        Pspice crash on attached design
1270879 ALLEGRO_EDITOR COLOR            Color view save creates .color file using older extension
1271295 SIP_LAYOUT     DIE_STACK_EDITOR Die stack editor support needed for large variant combination designs.
1271385 CONCEPT_HDL    CORE             Locked property can still be added
1271853 APD            OTHER            When using the beta "shape to cline" command, add improved messages and partial completion of individual segs in error.
1272197 CONCEPT_HDL    CORE             concepthdl_menu.txt contains invalid Variants menu
1272318 CAPTURE        GEN_BOM          BOM_IGNORE not working for Capture BOM on hierarchical designs.
1272743 ALLEGRO_EDITOR PADS_IN          PADS Library Translator does not open the Options dialog window.
1273517 F2B            PACKAGERXL       Netrev error - ERROR(40) Object not found in database
1274000 ALLEGRO_EDITOR DATABASE         PCB layer can't be removed
1274530 ALLEGRO_EDITOR INTERACTIV       Add Circle radius value changes next time using this command
1274697 PSPICE         AA_MC            pspiceaa crashes when running Advanced analysis monte carlo for the attached design
1275154 CONCEPT_HDL    CORE             Hierarchical Blocks lose ref designators when moved to another page
1275724 GRE            CORE             AiDT delete another clines
1275831 ALLEGRO_EDITOR DRC_CONSTR       Waived DRCs return when using multi-thread DRC check
1275834 CONCEPT_HDL    CORE             ERROR (SPCOCD-569) on global bus
1276334 ALLEGRO_EDITOR PADS_IN          PADS Library Import problem with outlines
1277062 ALLEGRO_EDITOR PLACEMENT        Swapping parts from top to bottom Orientation changes
1278746 ALLEGRO_EDITOR DRC_CONSTR       Package to package DRC allows place_bound_top in 0 spacing has drc in 16.6 version.
1278804 CONCEPT_HDL    COPY_PROJECT     Copy project crashes
1279362 ALLEGRO_EDITOR INTERACTIV       User SKILL file makes Allegro Icons gone away
1279619 ALLEGRO_EDITOR DRC_CONSTR       Netgroup in a Netclass doesn't inherit Spacing Cset
1279815 CONCEPT_HDL    CORE             Text > Change and RMB Editor does not allow multiple text edits
1279876 ALLEGRO_EDITOR DATABASE         Using the Curved option in Fillets results in a pad to shape DRC
1280435 F2B            BOM              BOMHDL with variant repeats the PART_NUMBER value
1281669 CONCEPT_HDL    COMP_BROWSER     Match Any radio button in Component Browser didn't work.
1282001 ALLEGRO_EDITOR DRC_CONSTR       Updating the DRCs on this design cause the DRC count to change on every update
1282480 SIP_LAYOUT     WIREBOND         Info on the Wire Count property needs to be updated indicating that it is a User Defined Property
1283952 ALLEGRO_EDITOR PLOTTING         Published pdf does not show dotted or phantom lines
1283957 ALLEGRO_EDITOR INTERACTIV       Replace padstack in "Single Via Replace Mode" is changing netname of the vias with the latest hotfix of Allegro 16.6
1285588 ALLEGRO_EDITOR DRC_CONSTR       Dynamic phase control has wrong analysis result when add rectangle test bead in Clines.
1286743 ALLEGRO_EDITOR SHAPE            Getting copper islands in the design after running the Delete Plating Bar command
1287215 ALLEGRO_VIEWER OTHER            Allegro viewer plus does not support constraint regions
1288808 APD            LOGIC            Derive Assignment stalls out or won?t finish and appears to run out of database room.
1289251 ALLEGRO_EDITOR SCHEM_FTB        Pin escapes (clines and vias) not inheriting new net name from a pin with a new net name.
1289293 F2B            DESIGNVARI       Warning 04: Cannot merge the variant properties on variant instance C119 component with same canonical path not present
1289809 SCM            VERILOG_IMPORT   User not able to import a verilog netlist into SCM
1290696 CONCEPT_HDL    CORE             Copying a net name repeatedly causes it to go off grid
1291162 CONCEPT_HDL    CREFER           crefer crashes when selecting generate cross refernece for all nets selected
1291285 SIP_LAYOUT     IMPORT_DATA      Replacing a Die with the Die Text in Wizard causes some Clines to Shift, creating new DRCs.
1291658 ALLEGRO_EDITOR INTERACTIV       Cannot add Frectangle to Group
1292180 ALLEGRO_EDITOR SKILL            Allegro Crash while performing query contents of "Maximum_Cavity_Size" with the skill command 'axlDBGetPropDictEntry'
1292210 CONCEPT_HDL    CORE             DEHDL crash if design was opened with -nonetlistuprev option.
1292278 SIP_LAYOUT     WIREBOND         When creating Wirebonds by Importing a Wirebond File, (wbt) the wirebonds are not on the correct Die layer
1292282 SIP_LAYOUT     INTERACTIVE      Getting Multiple GUIs when the Wirebond Import is open and we select outside the command GUI.
1293381 SIP_LAYOUT     IMPORT_DATA      Import SPD2 error
1293889 CONCEPT_HDL    PAGE_MGMT        page name regression result deleted by netassembler
1294124 ALLEGRO_EDITOR INTERACTIV       Samsung Mobile division wants to disappear the grids in the display window when zoom-out function executes in the allegr
1294749 ALLEGRO_EDITOR ARTWORK          Null pad is flagged as an error that break Thales automatic tape out
1294777 ALLEGRO_EDITOR SYMBOL           Mechanical symbols missed on STEP result
发表于 2014-8-30 04:20:13 | 显示全部楼层
发表于 2014-8-30 04:20:57 | 显示全部楼层
发表于 2014-8-30 04:21:44 | 显示全部楼层
发表于 2014-8-30 08:58:46 | 显示全部楼层
已经到Hotfix 33了
发表于 2014-11-28 11:33:06 | 显示全部楼层
试试看看
发表于 2014-11-28 15:27:26 | 显示全部楼层
多谢了!!!!
发表于 2016-6-13 15:24:21 | 显示全部楼层
谢谢分享。
GMT+8, 2025-12-30 20:39 , Processed in 0.143612 second(s), 6 queries , Gzip On, Redis On.
