查看: 2527|回复: 4
[招聘] Synopsys武汉 IP Center 热招ASIC/ Verification Engineer for DDR USB
发表于 2014-7-18 18:21:30 | 显示全部楼层 |阅读模式
If you have any interest in the position, please send your bilingual resume as
attachments to
dmliu@synopsys.com
Subject of your email should be “Your Name_ University_ Applied Position Title_ Location”
1\ Job Title: Digital IP Designer ( ASIC Design or Verification_
USB DDR MIPI SATA)
http://search.51job.com/job/53774338,c.html
Job responsibilities include understanding connectivity protocols like SATA, MIPI, SDMMC, AMBA, HDMI and working on the design/directed verification of designs in such protocols.
Be able to implement test benches and test cases in HDL like Verilog is needed.
Requirements:
- Has BSEE in EE with 3+ years of relevant experience or MS with 1+ years of relevant experience in one or more of the following areas:
- Has good background in RTL design and directed verification. Hands on experience with Verilog coding and Simulation tools
-Prior ASIC/IP directed verification skills with essential knowledge of Verilog/ System Verilog
-Synthesis flow and static timing flows, Formal checking, etc is a must for candidates with design background
2\Job Title: Mixed-signal IP Designer (Digital Design or Verification for
SerDes/ DDR PHY)
Job Responsibilities:
Develop and execute verification for IP level functional features related to DDR memory system.
Work closely with Design/Macro teams to identify the milestones and quality metrics of the project that includes scoping, tracking and delivery.
Participate in test environment infra and regression infra development, testbench development in VMM/SystemVerilog/C++, test cases development and debug.
Requirements
Must have BSEE in EE with 6+ years of relevant experience or MSEE with 4+ years of relevant experience in the following areas:
Verification experience of IP core or ASIC Design for DDR memory system or mix-signal system.
Hands on experience with creating test plan and test environment from Functional Specifications/ Test Environment Specifications with verification methodology of VMM/UVM.
Hands on experience with System Verilog/ VERA coding and Simulation tools; Knowledge of C++/ OOPs Concepts.
发表于 2014-7-21 13:06:06 | 显示全部楼层
domi liu,你好,居然在这里碰见你了
 楼主| 发表于 2014-7-25 18:24:09 | 显示全部楼层
回复 3# 袁斌
    哈哈 是啊 有合适的人欢迎推荐!
 楼主| 发表于 2014-7-25 18:25:06 | 显示全部楼层
Global 著名 IC公司 武汉R&D center扩招中,机会不容错过!
发表于 2014-7-25 19:58:15 | 显示全部楼层
为何非要有IC经验啊,做FPGA的应该可以考虑考虑啊。
GMT+8, 2025-12-26 22:25 , Processed in 0.016697 second(s), 6 queries , Gzip On, Redis On.
