查看: 19608|回复: 18
[原创] keil MDK最新版5.11a下载
发表于 2014-7-12 09:59:12 | 显示全部楼层 |阅读模式
http://pan.baidu.com/s/1kTJrA6r
Microcontroller Development Kit - Version 5.11a
This MDK release includes the Software Packs CMSIS Version 4.1 and MDK-Middleware Version 6.0 that are incompatible with the current STM32 Device Family Packs. The application note 266Using Keil MDK v5.11 with STM32 devices describes the reasons and the resolution.
    This MDK release includes the following fixes over MDK Version 5.11:
    • Updated μVision (V5.11.1.0):
      • gpdsc file reload problem fixed (Infineon DAVE3)
      • Select Software Packs dialog control via keyboard fixed
    • Updated SystemViewer.dll (V2.28.0):
      • Periodic window update for child elements fixed
      • Abort on Display of LPC4300 GPIO registers fixed
  • This MDK release includes the following Software Packs:
    • CMSIS V4.1.0 with new CMSIS-Driver API.
    • MDK-Middleware V6.0.0 that uses the new CMSIS-Driver API.
    These Software Packs are compatible with the new DFP Version 2.0.x or higher for Infineon and NXP. All future DFP's will rely on the above Software Packs.
    NOTE: For using middleware with EnergyMicro and ST devices that are based on DFP Version 1.x select CMSIS V3.2.x and MDK-Middleware V5.1.x as described under Select Software Packs.
  • This MDK release contains the following new components:
    • μVision V5.11.0.0 with new features for Select Software Packs.
    • Pack Installer V1.2 with minor bug fixes.
  • ARM Compiler
    • The absacc.h header file has been removed from the ARMCC/include folder. Use the _attribute_ syntax instead of the macro __at.
  • Target debugging
    • Updated: STMicroelectronics ST-Link driver for STMicroelectronics devices to version 2.0.6.0 to support STM32L0 devices.
    • Updated: NuLink software to version 6.2.11
发表于 2014-9-20 21:34:01 | 显示全部楼层
License在那里呀?
发表于 2014-9-22 09:45:13 | 显示全部楼层
License在那里呀?
发表于 2014-9-24 09:37:31 | 显示全部楼层
最新的版本好像不支持很多cortex A芯片
发表于 2015-5-7 10:43:56 | 显示全部楼层
zm下载
发表于 2015-7-2 12:40:08 | 显示全部楼层
发表于 2015-7-2 12:40:28 | 显示全部楼层
zm下载
发表于 2015-7-6 12:20:22 | 显示全部楼层
谢谢楼主的共享,谢谢!
发表于 2015-7-7 13:06:18 | 显示全部楼层
多谢啦啦啦
发表于 2015-9-8 14:09:00 | 显示全部楼层
好东西啊
GMT+8, 2025-12-16 08:50 , Processed in 0.021591 second(s), 6 queries , Gzip On, Redis On.
