查看: 1713|回复: 0
[招聘] NVIDIA英伟达上海急招ASIC Physical Design Engineer
发表于 2014-7-9 15:28:07 | 显示全部楼层 |阅读模式
亲们,
NVIDIA上海最近急招多位ASIC Physical Design Engineer, 需要3年及以上工作经验的。以下是职位描述,有兴趣的童鞋可以将简历发至:sasu@nvidia.com 或者加QQ详聊:524786472
GPU ASIC Physical Design engineer
As a senior member of our ASIC-PD team, you'll be working on streamlining thechip infrastructure process across product designs, focusing on full chiplayout planning (partitioning, planning clock distribution and other structure,methodology), partition/full chip timing closure (primetime scripts, othertools, etc) and gate-level design of high-speed logic
RESPONSIBILITIES:
·        Chipintegration and netlist generation
·        -Synthesis,Formal verification, netlist quality check
·        Workin conjunction with Place and Route Engineers to achieve timing closure forboth partition level and full chip level
·        Developand enhance entire timing flow from frontend (pre-layout) to backend(post-layout) at both chip and block level.
·        Developcustom timing scripts using tcl/primetime for clock skew analysis, specialcircuits such as clock dividers, core logic <-> IO macros interfaces suchas PCI-E, Frame-Buffer/Memory, TMDS, etc.
·        Developflow to physically partition and floorplan the entire chip.
·         Develop scripts for performing ECO's.
MINIMUM REQUIREMENTS:
·        BSor MS in Electrical Engineering or Computer Science
·        Above3 years of relevant ASIC experience ideally with a focus in the chipintegration /synthesis/formal and timing closure
·        -Excellent scripts skills
·        -Excellent written and verbal communication skills in English
·        -Ability to multiplex many issues, set priorities, and work in a teamenvironment
·        -Keep up to date with leading edge technologies
GMT+8, 2025-12-26 12:55 , Processed in 0.020858 second(s), 5 queries , Gzip On, Redis On.
