楼主: jianyungsun
[讨论] Cascode电流镜有没有提高电路PSRR的作用?
 楼主| 发表于 2014-7-19 11:40:10 | 显示全部楼层
回复 17# fuyibin
   can you give us more  details?
 楼主| 发表于 2014-7-19 11:43:00 | 显示全部楼层
回复 19# icdane
   我想问一下你说的电容分压是具体是怎么回事?
发表于 2014-7-19 20:36:14 | 显示全部楼层
in low power supply, it is very difficult to improve psrr. if your design is in 1V power domain, there is no enough headroom.
发表于 2014-7-20 00:05:43 | 显示全部楼层
testing
发表于 2014-7-20 00:51:23 | 显示全部楼层
回复 23# fuyibin if really headroom limited, i do not see much difference between these two. while i would put more cap as load.
发表于 2014-7-20 00:54:04 | 显示全部楼层
回复 24# semico_ljj
and assign more head room to the current source instead of adding a cascoding in the linear
发表于 2014-7-20 19:53:46 | 显示全部楼层
回复  fuyibin  if really headroom limited, i do not see much difference between these two. while i w ...
icdane 发表于 2014-7-20 00:51
if give you 100mV headroom, you can use larger channel length or use  cascode structure. one is 2 times output impedance improvement. the other is 10  times.
发表于 2014-7-21 13:58:09 | 显示全部楼层
回复 27# fuyibin
i do not see that much , anyway, this is design based, we always have options between these two
发表于 2014-8-7 15:04:56 | 显示全部楼层
都在瞎扯,不说问题的本质。
发表于 2015-3-30 15:14:40 | 显示全部楼层
表示还是不明白
GMT+8, 2025-9-16 08:00 , Processed in 0.016190 second(s), 3 queries , Gzip On, Redis On.
