楼主: min4max
Cadence IC616等套件以及Calibre2013的正规设置及使用,另附Jake Baker的教科书
发表于 2015-12-14 22:15:17 | 显示全部楼层
简直太给力,但我还是只想装在虚拟机上做做简单练习,不知可否实现。
发表于 2015-12-26 12:45:25 | 显示全部楼层
我出現以下calibre error, 請問有誰知道要如何解決???感恩啊
irtuoso Framework License (111) was checked out successfully. Total checkout time was 0.01s.
END OF USER CUSTOMIZATION
//  Calibre Error: Environment variable CALIBRE_HOME does not point to a directory. Calibre Skill Interface not loaded.
*WARNING* hiiSubEventShell: cannot display blocking dialog before initialization is complete.  It is likely that a command in your .cdsinit file is attempting to display a blocking dialog.  Please use hiEnqueueCmd() to put the command that displays the dialog into the command queue and it will be executed once initialization has completed.
发表于 2015-12-26 12:48:40 | 显示全部楼层
What happen??
Virtuoso Framework License (111) was checked out successfully. Total checkout time was 0.01s.
发表于 2015-12-28 16:01:20 | 显示全部楼层
学习了!
发表于 2016-1-7 13:27:42 | 显示全部楼层
Thanks!
发表于 2016-1-7 21:08:36 | 显示全部楼层
顶 顶
发表于 2016-1-8 08:22:45 | 显示全部楼层
thanks
发表于 2016-1-10 22:26:36 | 显示全部楼层
谢谢分享。楼主辛苦啦 !!!!
发表于 2016-1-11 10:12:14 | 显示全部楼层
Thank you for sharing
发表于 2016-1-12 08:30:56 | 显示全部楼层
楼主是牛人。准备按楼主的方法试一试。
GMT+8, 2025-10-21 05:14 , Processed in 0.018512 second(s), 5 queries , Gzip On, Redis On.
