楼主: min4max
Cadence IC616等套件以及Calibre2013的正规设置及使用,另附Jake Baker的教科书
发表于 2015-7-30 16:09:24 | 显示全部楼层
回复 11# 琴韵星空
这个教程在哪里  求分想享
发表于 2015-8-10 14:16:32 | 显示全部楼层
找了很多教程,觉得这是最让人易懂,且公用性最强的一次解说!
发表于 2015-8-13 15:47:23 | 显示全部楼层
thanks for sharing
发表于 2015-8-13 22:51:39 | 显示全部楼层
thank you ll
发表于 2015-8-16 23:05:29 | 显示全部楼层
真不赖
发表于 2015-8-21 20:42:59 | 显示全部楼层
坛里就是要多些像你一样的guider
发表于 2015-8-27 00:02:00 | 显示全部楼层
[zrway@alvin cadence_patch]$ ./cadence_patch.sh ../IC616
[total hits/matching patterns/non-matching patterns]
51% ...IC616/share/oa/bin/linux_rhel50_gcc44x_64/opt/oa2verilog : 0 cerror: failed to read+write: ../IC616/share/oa/bin/linux_rhel50_gcc44x_64/opt/oaFSLockD - skipping
54% ../IC616/tools.lerror: failed to read+write: ../IC616/tools.lnx86/bin/32bit/cdsNameServer - skipping
25% ../IC616/tools.lnx86/bin/cdsXvnc : 0 chanerror: failed to read+write: ../IC616/tools.lnx86/bin/clsbd - skipping
30% ../IC616/tools.lerror: failed to read+write: ../IC616/tools.lnx86/lib/64bit/SuSE/SLES11/libexpat.so.0 - skipping
error: failed to read+write: ../IC616/tools.lnx86/lib/64bit/SuSE/libexpat.so.0 - skipping
85457 files checked, 0 changed.
5 errors occurred.
[zrway@alvin ~]$ WARNING: HOST <alvin.server> DOES NOT APPEAR TO BE A CADENCE SUPPORTED LINUX CONFIGURATION.
         For More Info,  Please Run '<cdsroot>/tools.lnx86/bin/checkSysConf' <productId>.
发表于 2015-8-29 20:03:10 | 显示全部楼层
ok
发表于 2015-8-30 15:41:59 | 显示全部楼层
近来在搞cadence的软件,从头至尾看了楼主的帖子及相关回复,在下着实佩服~~~收藏ing.
发表于 2015-9-5 00:15:32 | 显示全部楼层
LICENSE只到2013怎么办?
GMT+8, 2025-12-18 04:57 , Processed in 0.019995 second(s), 4 queries , Gzip On, Redis On.
