查看: 5102|回复: 10
IC614 Virtual Machine
发表于 2014-7-7 05:44:40 | 显示全部楼层 |阅读模式
It is Pleasure to me to share with you this virtual machine
installed on this VM
IC614
MMSIM 7
ADS2011 (with dynamic link with cadence)
Sonnet 14
operating system is centos 6.4 (32 bit)
special thanks to my friend islam who made this VM
link.rar (149 Bytes , 下载次数: 66 )
发表于 2014-7-9 03:59:35 | 显示全部楼层
thank you
can i ask you how should i run ic614 ?
 楼主| 发表于 2014-7-9 16:54:09 | 显示全部楼层
Reply 2 # delphi40
here is the steps ReadmeFirst_2.pdf (24.6 KB , 下载次数: 46 )
发表于 2014-7-9 22:46:46 | 显示全部楼层
我只能说网址打不开。。。。
 楼主| 发表于 2014-7-10 00:33:09 | 显示全部楼层
Reply 4 # Accee
check  this
发表于 2014-7-10 10:55:59 | 显示全部楼层
11 GB (11,589,460,380 bytes)
..好大  vmware版本 vmdx image  ?
因為其他家 virtualBox 也是 virtual machine
 楼主| 发表于 2014-7-10 16:43:24 | 显示全部楼层
回复 6# peterlin2010
   it is the virtual machine only , you can download vmware (any version) and open it
发表于 2014-7-10 17:10:44 | 显示全部楼层
网址打不开
发表于 2014-7-14 09:23:44 | 显示全部楼层
跟不是virtual machine的執行比速度會變慢嗎?
发表于 2015-5-2 02:22:34 | 显示全部楼层
great post
GMT+8, 2025-12-20 20:01 , Processed in 0.023552 second(s), 8 queries , Gzip On, Redis On.
