查看: 5217|回复: 5
[原创] 关于AGC指数函数产生电路的疑惑
发表于 2014-7-1 10:57:58 | 显示全部楼层 |阅读模式
最近看了一篇关于AGC指数函数产生电路的论文,a low power monolithic AGC with automatic DC offset cancellation for direct conversion hybrid CDMA transceiver used in telemetering。对文中关于指数函数产生电路有一点疑惑。
    文中VGA的指数函数产生电路如下图所示:
VGA指数函数产生电路
VGA指数函数产生电路
    关于这个电路的描述是这样的:The biasing currents of the VGA are varied by a simple gain controller, Fig.4. The controller is mainly composed of a differential pair. The currents, which flow in two current sources - M7&8, are controlled by M1&2. M3&4 are added to improve the VGA‘s gain in decibels which changes more linearly with the control voltage(Fig.5). The gate of M1&2 are connected to Vctr and ground respectively. By varying the Vctr from 0V to 1.5V, the gain of the VGA sweeps from minimum to maximum(Fig.5).
     不知道这个电路的指数表达式是如何推导出来的?求高手解释
 楼主| 发表于 2014-7-1 11:05:55 | 显示全部楼层
 楼主| 发表于 2014-7-3 08:39:29 | 显示全部楼层
顶一下,求高手回答
发表于 2014-7-4 09:20:41 | 显示全部楼层
帮顶,同问
 楼主| 发表于 2014-7-7 15:56:17 | 显示全部楼层
再顶一个
发表于 2021-11-3 22:33:35 | 显示全部楼层
楼主,请问解决了吗?我也看到了这篇文章,这个电路没看懂
GMT+8, 2025-12-24 06:14 , Processed in 0.019352 second(s), 7 queries , Gzip On, Redis On.
