查看: 7895|回复: 12
[资料] MIPI CSI2 VIP
发表于 2014-6-27 23:21:14 | 显示全部楼层 |阅读模式
对于MIPI CSI2的Tansmitter 或Receiver,都可通过WWAGO的MIPI CSI-2 Verification IP来进行Verify.这样可大大节省验证的时间。如有感兴趣的,可以直接联系WWAGO公司的销售sales@wwago-inc.com,申请试用。
WWAGO MIPI CSI-2 Verification IP provides an effective & efficient way to verify the components interfacing with MIPI CSI-2 interface of an IP or SoC
the MIPI CSI-2 VIP is fully compliant with Standard MIPI CSI-2 Version 1.1 Specifications from MIPI Alliance. This VIP is a light weight VIP with easy plug-and-play interface so that there is no hit on the design time and the simulation time.
MIPI CSI-2 VIP的BLOCK图如下:
MIPI CSI-2 VIP的详细文档如下:
WWAGO_MIPI_CSI2_VIP_Datasheet.pdf (377.64 KB , 下载次数: 180 )
发表于 2014-10-9 14:51:29 | 显示全部楼层
楼主能否将所有的放到一个帖子里?
发表于 2015-4-20 17:55:20 | 显示全部楼层
Thank you
发表于 2015-9-25 16:22:15 | 显示全部楼层
Thank you
发表于 2016-1-13 16:59:44 | 显示全部楼层
是广告而已!!!
发表于 2016-1-15 16:47:45 | 显示全部楼层
MIPI CSI2 VIP
发表于 2018-3-4 10:53:16 | 显示全部楼层
又不是很难的东西,吹得那么牛逼。。
发表于 2019-7-3 17:03:36 | 显示全部楼层
Thanks
发表于 2019-11-22 17:36:28 | 显示全部楼层
了解一下也好
发表于 2020-10-28 20:56:16 | 显示全部楼层
thanks !
GMT+8, 2025-12-18 03:25 , Processed in 0.024103 second(s), 8 queries , Gzip On, Redis On.
