楼主: Leslie-T
Cadence SPB16.60 + Hotfix 30 Linux
发表于 2014-7-13 20:22:29 | 显示全部楼层
Leslie-T兄, 麻烦帮忙看看Hotfix030安装时候出现的问题,说是有29个文件找不到,感觉Hotfix030包像是不完整。安装环境是ubuntu12.04 amd64
The file /home/eda/CadenceSPB16.6_Linux/Hotfix030/tmp/SPB16.60.030_lnx86.Hotfix/CDROM1/kits/pcbopgcommonDoc16.60-s002.t.Z was not found.
com.util.ISException:The file /home/eda/CadenceSPB16.6_Linux/Hotfix030/tmp/SPB16.60.030_lnx86.Hotfix/CDROM1/kits/specctra16.60-s013lnx86.t.Z was not found.
com.util.ISException:The file /home/edaCadenceSPB16.6_Linux/Hotfix030/tmp/SPB16.60.030_lnx86.Hotfix/CDROM1/kits/pcbrtetutDoc16.60-s002.t.Z was not found.
com.util.ISException:The file /home/eda/CadenceSPB16.6_Linux/Hotfix030/tmp/SPB16.60.030_lnx86.Hotfix/CDROM1/kits/simSetup16.60-s010lnx86.t.Z was not found.
com.util.ISException:The file /home/eda/CadenceSPB16.6_Linux/Hotfix030/tmp/SPB16.60.030_lnx86.Hotfix/CDROM1/kits/psetup16.60-s005lnx86.t.Z was not found.
com.util.ISException:The file /home/eda/CadenceSPB16.6_Linux/Hotfix030/tmp/SPB16.60.030_lnx86.Hotfix/CDROM1/kits/projMgr16.60-s007lnx86.t.Z was not found.
com.util.ISException:The file /home/eda/CadenceSPB16.6_Linux/Hotfix030/tmp/SPB16.60.030_lnx86.Hotfix/CDROM1/kits/pxlDoc16.60-s004.t.Z was not found.
com.util.ISException:The file /home/eda/CadenceSPB16.6_Linux/Hotfix030/tmp/SPB16.60.030_lnx86.Hotfix/CDROM1/kits/sprouteIndep16.60-s001.t.Z was not found.
com.util.ISException:The file /home/eda/CadenceSPB16.6_Linux/Hotfix030/tmp/SPB16.60.030_lnx86.Hotfix/CDROM1/kits/rfsipPcellIndep16.60-s001.t.Z was not found.
com.util.ISException:The file /home/eda/CadenceSPB16.6_Linux/Hotfix030/tmp/SPB16.60.030_lnx86.Hotfix/CDROM1/kits/standardinte16.60-s002lnx86.t.Z was not found.
com.util.ISException:The file /home/eda/CadenceSPB16.6_Linux/Hotfix030/tmp/SPB16.60.030_lnx86.Hotfix/CDROM1/kits/sipGXLDoc16.60-s016.t.Z was not found.
com.util.ISException:The file /home/eda/CadenceSPB16.6_Linux/Hotfix030/tmp/SPB16.60.030_lnx86.Hotfix/CDROM1/kits/pwizard16.60-s009lnx86.t.Z was not found.
com.util.ISException:The file /home/eda/CadenceSPB16.6_Linux/Hotfix030/tmp/SPB16.60.030_lnx86.Hotfix/CDROM1/kits/smi16.60-s007lnx86.t.Z was not found.
com.util.ISException:The file /home/eda/CadenceSPB16.6_Linux/Hotfix030/tmp/SPB16.60.030_lnx86.Hotfix/CDROM1/kits/rfsipPcell16.60-s004lnx86.t.Z was not found.
com.util.ISException:The file /home/eda/CadenceSPB16.6_Linux/Hotfix030/tmp/SPB16.60.030_lnx86.Hotfix/CDROM1/kits/rfpcbfe16.60-s016lnx86.t.Z was not found.
com.util.ISException:The file /home/eda/CadenceSPB16.6_Linux/Hotfix030/tmp/SPB16.60.030_lnx86.Hotfix/CDROM1/kits/pcbproprefDoc16.60-s016.t.Z was not found.
com.util.ISException:The file /home/eda/CadenceSPB16.6_Linux/Hotfix030/tmp/SPB16.60.030_lnx86.Hotfix/CDROM1/kits/rfpcbcnSKILL16.60-s001lnx86.t.Z was not found.
com.util.ISException:The file /home/eda/CadenceSPB16.6_Linux/Hotfix030/tmp/SPB16.60.030_lnx86.Hotfix/CDROM1/kits/sigXplorer16.60-s026lnx86.t.Z was not found.
com.util.ISException:The file /home/eda/CadenceSPB16.6_Linux/Hotfix030/tmp/SPB16.60.030_lnx86.Hotfix/CDROM1/kits/pcbcommonDoc16.60-s001.t.Z was not found.
com.util.ISException:The file /home/eda/CadenceSPB16.6_Linux/Hotfix030/tmp/SPB16.60.030_lnx86.Hotfix/CDROM1/kits/rfsipOaLayout16.60-s004lnx86.t.Z was not found.
com.util.ISException:The file /home/eda/CadenceSPB16.6_Linux/Hotfix030/tmp/SPB16.60.030_lnx86.Hotfix/CDROM1/kits/rfsipOA16.60-s009lnx86.t.Z was not found.
com.util.ISException:The file /home/eda/CadenceSPB16.6_Linux/Hotfix030/tmp/SPB16.60.030_lnx86.Hotfix/CDROM1/kits/sipVirtuosoSkl16.60-s001lnx86.t.Z was not found.
com.util.ISException:The file /home/eda/CadenceSPB16.6_Linux/Hotfix030/tmp/SPB16.60.030_lnx86.Hotfix/CDROM1/kits/productServer16.60-s004lnx86.t.Z was not found.
com.util.ISException:The file /home/eda/CadenceSPB16.6_Linux/Hotfix030/tmp/SPB16.60.030_lnx86.Hotfix/CDROM1/kits/veditWNDoc16.60-s006.t.Z was not found.
com.util.ISException:The file /home/eda/CadenceSPB16.6_Linux/Hotfix030/tmp/SPB16.60.030_lnx86.Hotfix/CDROM1/kits/veditUGDoc16.60-s007.t.Z was not found.
com.util.ISException:The file /home/eda/CadenceSPB16.6_Linux/Hotfix030/tmp/SPB16.60.030_lnx86.Hotfix/CDROM1/kits/rfsipCoreCxt16.60-s038.t.Z was not found.
com.util.ISException:The file /home/eda/CadenceSPB16.6_Linux/Hotfix030/tmp/SPB16.60.030_lnx86.Hotfix/CDROM1/kits/rfpcbfeugDoc16.60-s004.t.Z was not found.
com.util.ISException:The file /home/eda/CadenceSPB16.6_Linux/Hotfix030/tmp/SPB16.60.030_lnx86.Hotfix/CDROM1/kits/vedit16.60-s014lnx86.t.Z was not found.
com.util.ISException:The file /home/eda/CadenceSPB16.6_Linux/Hotfix030/tmp/SPB16.60.030_lnx86.Hotfix/CDROM1/kits/sigXpIndep16.60-s016.t.Z was not found.
 楼主| 发表于 2014-7-14 03:58:57 | 显示全部楼层
回复 31# sdecat
Strange. I will check it and reupload tomorrow!
发表于 2014-7-14 10:13:02 | 显示全部楼层
我也是同样的错误
 楼主| 发表于 2014-7-15 00:58:51 | 显示全部楼层
I've uploaded again, however it is the latest hotfix(31) instead of old one.
UPDATED KITS RELEASE: ISR 16.60.031
http://pan.baidu.com/s/1ntK9Sxj
发表于 2014-7-15 13:49:43 | 显示全部楼层
回复 34# Leslie-T
发表于 2014-8-2 22:20:17 | 显示全部楼层
mark,谢谢分享。。另,现在最新032
发表于 2014-8-23 07:03:42 | 显示全部楼层
谢谢分享
发表于 2014-9-3 17:07:15 | 显示全部楼层
如果这次能成功就太感谢了。
发表于 2014-9-9 21:05:25 | 显示全部楼层
Awesome!
发表于 2014-9-22 21:29:39 | 显示全部楼层
太伟大了!
非常感谢
GMT+8, 2025-9-18 21:14 , Processed in 0.023475 second(s), 7 queries , Gzip On, Redis On.
