查看: 2545|回复: 2
[求助] PT问题,跑不下去了,求助 (RC-005) (RC-008)
发表于 2014-6-10 08:52:54 | 显示全部楼层 |阅读模式
用PT做post-layout分析时,运行check_timing -verbose时,出现如下警告,一晚上了还是停在RC-008的警告上,没有结果!
运行了man (RC-005) (RC-008),也看不出啥原因,在线等高手。
Warning: Failed to compute the rising RCnetwork delay from the pin 'sys_clk' to the pin 'sys_clk__L1_I0/A' in the network 'sys_clk'. (RC-005)
Warning: The type of RC delay calculationproblem(s) that have occured prevents the max results from bounding the correct values. (RC-008)
发表于 2014-6-10 09:42:20 | 显示全部楼层
could you please check this path is constrained or unconstrained  firstly ?
then Could you check the variable  " timing_slew_propagation_mode" value ?
best regards
 楼主| 发表于 2014-6-10 13:20:31 | 显示全部楼层
回复 2# yangwuqing40
timing_slew_propagation_mode is worst slew,有影响吗?
GMT+8, 2025-12-19 11:27 , Processed in 0.018836 second(s), 5 queries , Gzip On, Redis On.
