查看: 7379|回复: 0
[原创] Allegro导出器件坐标和转角和封装到Excel表格中
发表于 2014-6-6 16:32:32 | 显示全部楼层 |阅读模式
该段代码使用了Allegro 16.6中提供的有关对Microsoft Excel支持的函数,生成的置件坐标可以直接在Excel中打开。
请将该段存为以.ils为扩展名的文件,因为它使用了嵌套的函数定义。
作为Lisp的一名忠实拥趸,我非常讨厌SKILL中使用Franz-Lisp 运算符Infix的风格;即使对于像plus这类的样的函数。
最后,欢迎拍砖或者和通过邮件和我讨论。
;; Author: willvcn
;; Email: willvcn@gmail.com
;; Last Rivised: 2014-06-06
;; This program generate a spreadsheet compoent placement report in Microsoft excel
;; XML formate, it has been tested with Allegro 16.6 and Microsoft Excel 2003.
(defun genPlacement () ; Initialize an empty spreadsheet.
  ;;procedure init the spreadsheet
  (procedure (initSpreadsheet)
(progn
   (axlSpreadsheetInit)
   ;; Define inital, default style.
   ;; Styles may be defined at any point during the spreadsheet's
   ;; construction, but must be defined before they are referenced
   ;; by any row, column, or cell.
   (axlSpreadsheetSetStyle "Default" nil)
   (axlSpreadsheetSetStyleProp "Alignment" "Vertical" "Top")
   (axlSpreadsheetSetStyleProp "Alignment" "Horizontal" "Left")
   (axlSpreadsheetSetStyleProp "Alignment" "WrapText" "1")
   ;;title cell style
   (axlSpreadsheetSetStyle "Title" "TC")
   (axlSpreadsheetSetStyleParent "Default")
   (axlSpreadsheetSetStyleBorder "Top" nil "Continuous" "2")
   (axlSpreadsheetSetStyleBorder "Bottom" nil "Continuous" "2")
   (axlSpreadsheetSetStyleProp "Font" "FontName" "Arial Unicode MS")
   (axlSpreadsheetSetStyleProp "Font" "Bold" "1")
   ;;content cell style
   (axlSpreadsheetSetStyle "Content" "CNT")
   (axlSpreadsheetSetStyleBorder "Bottom" nil "Continuous" "1")
  ;;procedure to save spreadsheet to disk
  (procedure (saveSpreadsheet)
(let ((tSheetFile (axlDMFileBrowse "ALLEGRO_XML" t ?title "Save placement data to")))
(progn
   ;; Write the compiled spreadsheet to XML file on disk.
   (axlSpreadsheetWrite tSheetFile)
   ;; Close and release the compiled spreadsheet's data.
   (axlSpreadsheetClose)
  ;;define a structure to hold the placement info
  (defstruct _compInfo
footprint
    angle
y
ref
  ;;procedure to get component infomation from a comp dbid
  (procedure (getCompInfo dbComp)
(make__compInfo
  ?ref dbComp->name
  ?x (car dbComp->symbol->xy)
  ?y (cadr dbComp->symbol->xy)
  ?angle dbComp->symbol->rotation
  ?footprint dbComp->symbol->name
  ;;procedure print out the line
  (procedure (printTitleLine totLine n)
(if (null totLine)
t
   (let ((tcell (sprintf s "%s" (car totLine))))
(progn ;(axlSpreadsheetSetColumnProp n "Width" "100")
   (axlSpreadsheetDefineCell 1 n "Title" "String" tcell)
   (printTitleLine (cdr totLine) (plus n 1))))))
  ;;get the max length of the content
  (procedure (getColumnMaxLen lColumn)
(car (sort (mapcar (lambda (s) (strlen (sprintf _s "%L" s))) lColumn) 'greaterp)))
  ;;procedure print out a content column
  (procedure (printColumn lColumn r n tFmt)
(if (null lColumn)
t
   (let ((tcell (sprintf s tFmt (car lColumn)))
(tCellFmt (if (eq tFmt "%s")
   "String"
"Number")))
(progn
   (axlSpreadsheetDefineCell r n "Content" tCellFmt tcell)
   (printColumn (cdr lColumn) (plus r 1) n tFmt)))))
  ;;procedure to print all columns
  ;;the caar of column is the header line
  ;;the lColumns is [(lColumn tFmt)]
  (procedure (printColumns lColumns n)
(if (null lColumns)
t
   (let ((lColumn (car lColumns)))
(progn
   (axlSpreadsheetSetColumnProp n "Width" (sprintf s "%n" (times 7 (getColumnMaxLen (car lColumn)))))
   (printColumn (cdr (car lColumn)) 2 n (cadr lColumn)) ;print start from row number 2
   (printColumns (cdr lColumns) (plus n 1))))))
  (let ((lCompTop (setof aComp (axlDBGetDesign)->components (not aComp->symbol->isMirrored)))
(lCompBot (setof aComp (axlDBGetDesign)->components aComp->symbol->isMirrored)))
(let ((lCompInfoTop (mapcar getCompInfo lCompTop))
  (lCompInfoBot (mapcar getCompInfo lCompBot)))
  (progn
(initSpreadsheet)
;;write the top side
(progn
  (axlSpreadsheetSetWorksheet (sprintf s "Top(%s)" (car (axlDBGetDesignUnits))))
  (printTitleLine (car lCompInfoTop)->? 1)
  (printColumns (list (list (cons "ref" lCompInfoTop~>ref) "%s")
  (list (cons "x" lCompInfoTop~>x) "%g")
  (list (cons "y" lCompInfoTop~>y) "%g")
  (list (cons "angle" lCompInfoTop~>angle) "%g")
  (list (cons "footprint" lCompInfoTop~>footprint) "%s"))
1))
;;write the bottom side
(progn
  (axlSpreadsheetSetWorksheet (sprintf s "Bot(%s)" (car (axlDBGetDesignUnits))))
  (printTitleLine (car lCompInfoBot)->? 1)
  (printColumns (list (list (cons "ref" lCompInfoBot~>ref) "%s")
  (list (cons "x" lCompInfoBot~>x) "%g")
  (list (cons "y" lCompInfoBot~>y) "%g")
  (list (cons "angle" lCompInfoBot~>angle) "%g")
  (list (cons "footprint" lCompInfoBot~>footprint) "%s"))
1))
;;write and close
(saveSpreadsheet)
GMT+8, 2025-12-28 16:13 , Processed in 0.015223 second(s), 6 queries , Gzip On, Redis On.
