查看: 2155|回复: 1
[招聘] Synopsys DDR PHY CAE
发表于 2014-6-5 11:49:39 | 显示全部楼层 |阅读模式
Job Title: Synopsys DDR Fire CAEJob Location: Shanghai
接受简历地址: zhuqin.tang@synopsys.com
Job Description:
Description
• As a Corporate Applications Engineer (CAE) team in the Solutions Group at Synopsys, you will be responsible for technical support of customers using Synopsys DesignWare DDRn IP. You will analyze and resolve complex IP usage issues and provide timely, accurate technical guidance to customers. You will be interfacing with our Design Engineering team to report on any issues related to the IP’s design, reliability and maintenance or defects. You will have the capability to design and implement solutions to complex application problems independently with little guidance. You will be authoring application-notes and/or white-papers that promote the IP’s ease of use, or address specific challenges in the IP’s usage. You may be called upon to author technical papers and present them in peer-reviewed technical publications or conferences. You will have regular contact with external customers and internal contacts across cross-functional teams. Occasional travel will be required.
Requirements
• Qualified applicants will have a BSEE, MSEE, + 5 years relevant experience in ASIC design.
• Strong communication skills and ability to interact with customers as well as peers is required.
• Recent experience with ASIC implementation EDA tools and flows in the areas of Synthesis, Simulation, STA, Verification, Testability, Place and Route, Design Reuse and/or Physical Design is highly desired.
• Domain knowledge of the DDR3/2 Protocols with relevant experience is a plus.
• Hardware debug and troubleshooting skills are highly desirable.
• Relevant experience in design, implementation or technical support with mixed signal designs is highly desired.
 楼主| 发表于 2014-6-6 10:51:55 | 显示全部楼层
自己顶一下
GMT+8, 2025-12-26 07:13 , Processed in 0.012117 second(s), 4 queries , Gzip On, Redis On.
