查看: 3248|回复: 3
[解决] crystal oscillator simulation problem ..
发表于 2014-5-30 23:22:35 | 显示全部楼层 |阅读模式
hello everybody im doing a crystal oscillator and simulating it using cadence ic6
my problem is when i use moderate transient accuracy the results show oscillation .. but when i use conservative transient simulation there is absolutely no oscillation in the results ! and no matter what the transient step is !! how can is solve this problem ?
thanks a lot
发表于 2014-11-25 10:33:46 | 显示全部楼层
who know it ?!
发表于 2014-12-2 23:56:55 | 显示全部楼层
Maybe  it doesn't oscillate.
r u using transient analysis? just try to give a initial current condition in inductance of the motional arm, and increase Cm (to decrease Q, thus the start up time will decrease.) make sure you gm is about 2~3X larger than calculated gmcrit.  and give it a long time transient. hundreds of usecond. and the maxstep also matters. set it to period/100 or less. then try it again.
you also should try PSS with shooting engin and oscic=linear (refer to the spectreRF user guide ). if it converges, check the one period waveform. that will be the stable waveform.
发表于 2018-7-30 14:55:28 | 显示全部楼层
回复 1# elec_888
    谢谢谢谢
GMT+8, 2025-12-23 23:42 , Processed in 0.015290 second(s), 5 queries , Gzip On, Redis On.
