查看: 3215|回复: 5
[求助] 求IEEE文章
发表于 2014-5-23 16:39:51 | 显示全部楼层 |阅读模式
A Low-Power Wideband Reconfigurable Integrated Active-RC Filter With 73 dB SFDR
In this paper, a low-power, highly linear, integrated, active-RC filter exhibiting a reconfigurable transfer function (Chebyshev, Elliptic) and bandwidth (5 MHz, 10 MHz), is presented. The filter exploits digitally-controlled polysilicon resistor banks and a digital automatic tuning scheme to account for process and temperature variations. The operational amplifiers used are based on a new compensation technique that allows optimized high-frequency filter performance and minimized current consumption. A filter prototype has been fabricated in a 0.12-mum CMOS process, occupies 0.25 mm2 (tuning circuit included), and achieves an IIP3 of approximately +20 dBm, whereas its spurious free dynamic range (SFDR) reaches 73 dB. The dissipation of the filter core and the tuning circuit is 4.6 mW and 1.5 mW, respectively
Published in:Solid-State Circuits, IEEE Journal of (Volume:41 ,  Issue: 9) Date of Publication:Sept. 2006
非常感谢
发表于 2014-5-23 19:56:00 | 显示全部楼层
帮楼主找到了……
A Low-Power Wideband Reconfigurable.pdf
1.71 MB, 下载次数: 26 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2014-5-26 10:08:02 | 显示全部楼层
非常感谢提供!
 楼主| 发表于 2014-5-26 10:19:28 | 显示全部楼层
非常感谢
 楼主| 发表于 2014-5-26 17:03:39 | 显示全部楼层
再求一篇文章
A Fourth Order Elliptic Low-Pass Filter with Wide Range of Programmable Bandwidth, Using Four Identical Integrators
A new method to implement elliptic filter with identical integrators and no derivatives is presented. Using identical capacitor arrays as opposed to highly spread capacitor arrays of conventional implementation makes elliptic filter design with wide range of programmable/tunable bandwidths extremely simple, time-efficient and accurate. The proposed method also reduces the die size while realizing elliptic filter more faithfully. To demonstrate the method, a fourth order elliptic filter with nine programmable bandwidths ranging from 1.1 MHz to 17.6 MHz is designed. The 1.75 mm2 filter draws 10 mA from 3.3 V supply at output swing of 4.0 V ppd in 0.35 um CMOS process to meet less than 50 nV radicHz in-band output-referred noise and SFDR of better than 80 dBc.
Published in:
Custom Integrated Circuits Conference, 2007. CICC '07. IEEE
Date of Conference:
16-19 Sept. 2007
非常感谢
发表于 2014-12-12 11:07:29 | 显示全部楼层
不錯的文章~
謝謝二樓分享
GMT+8, 2025-12-26 09:08 , Processed in 0.027961 second(s), 7 queries , Gzip On, Redis On.
