查看: 2151|回复: 0
[求助] 用modelsim时序仿真乘法器时出现value out of range 的错误
发表于 2014-5-17 12:20:07 | 显示全部楼层 |阅读模式
在ISE里面调用ip核产生了25*18的乘法器,2级流水,然后再modelsim里面仿真时出现如下问题:
** Fatal: (vsim-3421) Value 1095521093 for use_dport is out of range 0 to 1.
#    Time: 0 ps  Iteration: 0  Instance: /multi/\multi_1/blk00000003  File: D:/software/xilink/ISE_DS/ISE/vhdl/src/simprims/primitive/mti/X_DSP48E1.vhd Line: 503
# FATAL ERROR while loading design
# Error loading design
这是怎么回事啊?  我加载的库有simprim,unisim ,xilinxipcore-lib
GMT+8, 2025-12-26 07:44 , Processed in 0.020076 second(s), 8 queries , Gzip On, Redis On.
