查看: 2490|回复: 0
[招聘] [招聘]Marvell美满电子招软件/后端/ASIC 工程师
发表于 2014-4-30 14:04:18 | 显示全部楼层 |阅读模式
If you have any interest in the position,please send your bilingual resume as
attachments to al-china-hr@marvell.com
Subject of your email should be “Your Name_University_Applied Position Title”
薪资:10K以上
1.
Job TitleWifi/ BT/ NFCSoftware Engineer
Job Description:
Seniorsoftware engineer to work on WLAN, Bluetooth and NFC software
developmentand platform integration for APSE
1) DevelopWiFi (IEEE 802.11 a/b/g/n), Bluetooth and NFC
middleware/applicationon Android platform.
2) Optimizepower consumption and performance of WiFi, Bluetooth and NFC
subsystems onAndroid platform.
3) DevelopAndroid GUI, framework and applications to enable new use cases of
WiFi,Bluetooth and NFC connectivity features.
4) Supportcustomer porting/debugging remotely or onsite as needed.
5) Creativeinnovation based on WLAN, Bluetooth and NFC
Link:http://search.51job.com/job/54680439,c.html –SH
http://search.51job.com/job/54680440,c.html–NJ
2.
Job Title:Firmware Engineer
Job Description:
This is an entry level,firmware engineering oriented system engineer position. The engineer will bepart of the vertical system engineering team composed with hardwareengineering, software engineering, firmware engineering, FPGA designengineering, signal integrity engineering, and others. The IC products to workwith include Ethernet PHY/NIC/Switch/SoC, high speed SerDes based PHYs, DTVfront end components, PLC PHYs, and so on. System engineering team isresponsible for many post silicon engineering efforts like product validation,platform development, collateral development, technical support and so on.
Job Responsibilities:
- Boot Code Development.
- BSP Development.
- API Driver Suite Development.
- Protocol Stack Firmware Development.
- Application Level Firmware Development.
- Technical Support to Customers.
JobQualification:
- BS/MS in EE/CE/CS.
- Must have good program skill.
- Must be familiar with embedded system.
- Must have good knowledge with computer system and data network system.
- Must be willing to work in a multi-tasking, fast pace, team oriented workingenvironment.
- Must be able to quickly absorb different kinds of knowledge and apply them inthe works.
- Working experience on firmware/software development are preferred.
- Familiarity with Ethernet and network protocols are some pluses.
3.
Job Title: CPUSoftware Engineer - Android VM, Browser and System
LocationShanghai
Business Unit Introduction::
CPU R&D group in Shanghai is chartered to develop and deliverworld-class high
frequency and low power CPUs which are compatible to ARM v7/8 ISA,joint-designwith Operating System and Virtual Machine for mobile and server.
The group alsodelivers high quality and complete development tools,modeling and optimizationsolutions for Marvell CPUs in Marvell applicationprocessors, communicationprocessor, video processors, storage processors,printer processors and etc.
With company's business and R&D expansion in China, we arelooking for talentedengineers who would like to join us to experience theopportunities from
Marvell's rapid growth.
Job Description:
The work includes software design/development of following projectsfor Marvell CPUs:
- Solution of optimized Java VM in Android (Dalvik and ART);
- Solution of optimized Android system including Linux for best UIand stystem performance;
- Solution of optimized browsers for Android;
- Solution of profiling and tracing tools for VM/system performanceanalysis
Qualifications and Responsibilities:
- BS/MS/PhD in electronic engineering/computer science (orequivalent).
- Strong advanced low power CPU, memory controller and system bus
architecture/micro-architecture knowledge.
- Strong C/C++ programming skills, and/or Java programming skills.
- Research or working experience in any relevant projects describedabove.
- Knowledge of ARM architecture, profiling and optimization is agreat advantage.
- Cooperative team player with good communication and teamworkskill.
- Fluent communication in both Chinese and English is an advantage.
4.
Job Title: SeniorCamera Software Engineer
Job Description:
In thisposition, you will be involved in the Camera related software development forTablet platform. Responsibilities include Camera driver/middleware/application development, performance optimization and systemintegration, etc.
Qualification:
- 3 years+camera related development/support experience.
- Familiarwith camera sensor, ISP knowledge.
- Solidexperience on Windows mobile and/or Android platform driver development.
- Strong in Cand/or C++ coding expertise.
- Solidcommunications skills, Good team work spirit.
- Camerasub-system architecture knowledge, middleware and application developmentexperiences on Windows and/or Android.
- Goodknowledge base in Image Processing, e.g. Auto White-Balance, Auto Exposure,Auto Focus, Digital Image Stabilization and Face Detection/Recognition, etc.
5.
Job Title: Sr.Software Engineer in Test
Description:
In theposition, the candidate will be responsible for creating and executing the testsuite/cases, test tools, and automation system to assure the quality ofsoftware platforms, which cover components from low level boot-loader, devicedriver, OS, middleware (multimedia and graphics), and up to high levelapplication framework (like Android), and Marvell proprietary compiler/debugger/performancetools.
His/her responsibilities will include but not belimited to
- Identify thefunctionality, stability, performance and power quality criteria for the wholesystem or individual components;
- Execute testsuites to reach defined test coverage and debugging requirement.
The candidate should possess a Bachelor of Science degree in ElectronicEngineering, Computer Science with relevant experiences, or Master of Sciencedegree in Electronic Engineering, Computer Science with relevant experience, orequivalent.
The candidate is expected to have below extraqualifications:
- Programmingskill in C, C++ and scripting language, i.e. Perl, python, is a must.
- Knowledge orworking experience in projects similar to above projects is preferred.
-Experience ingeneral embedded software development/debugging/validation and its automationis a plus.
-Leadershipexperience in either software validation or development is a plus.
-Technicalinfluence and interpersonal influence experience in multi-national company is amust. (English and Mandarin)
6.
Job Title: (Sr.)ASIC Design Verification Engineer
Position description:
Run simulationfor module and chip level (mainly in SerDes IP/Chip), work closely withdesigner;
Develop andexecute verification plan;
Define,implement and analysis functional/code coverage;
Develop/maintain/enhanceenvironment (TB/tools/scripts/flow).
Requirement:
-MS in EE
-Proficientand experienced in one of the high level verification methodology (VMM, UVM);
-Experiencedwith hardware verification language (Vera, SystemC, SystemVerilog)
-Proficientwith Verilog HDL;
-Proficientwith at least one scripting languages, e.g. Csh, Bash, Perl, Tcl
-Familiar withASIC design flow
-Experiencedin SerDes PHY(USB3, SATA, SAS, PCIE etc) is a plus.
7.
Job Title(Sr.) Physical Design Engineer
Job Description:
PhysicalDesign Engineer will support physical design requirement of different businessunit of Marvell, the main responsibility is:
-physicalimplementation, including floor-plan, power routing, placement, clock treesynthesis, timing closure, routing, si fixing, drc fixing, dfm ...etc
-physicalverification: including low power check, timing analysis, timing eco, x-talkanalysis, power analysis, ESD analysis, EM analysis, drc check, lvs check, ant check,erc check ...etc
-tape-out:timing signoff, power signoff, design tape-out... etc
Senior Link:
http://search.51job.com/job/52999451,c.html–SH
http://search.51job.com/job/51115532,c.html–NJ
http://search.51job.com/job/53798442,c.html–CD
Junior Link:
http://search.51job.com/job/41671945,c.html–SH
http://search.51job.com/job/54407707,c.html–NJ
http://search.51job.com/job/48831486,c.html–BJ
8.
Job Title: GPSSoftware Engineer
Job Description:
1. LSQ/KF GNSSPVT development and debugging on embedded system
2.Measurements management and analysis
3.Measurements feedback for GNSS baseband using; help baseband doing the
analysis anddebug.
4. Basic dataanalysis tool development
Link:http://search.51job.com/job/42341731,c.html –SH
http://search.51job.com/job/52032821,c.html–NJ
GMT+8, 2025-12-26 03:15 , Processed in 0.021481 second(s), 7 queries , Gzip On, Redis On.
