查看: 2359|回复: 2
[求助] 自己写的mbist memory model,mbist时,报Inconsistent models and instances
发表于 2014-4-30 11:22:04 | 显示全部楼层 |阅读模式
自己写的mbist memory model,用mentor的mbista做mbist,但报如下问题:
BIST Generation failed: Inconsistent models and instances
大神给看看,是我的memory model写的有问题吗?
是128X60的RAM,自己写的memory model如下:
model RAM128X60 (A, I, IA, DM, CK, CE, WE, SLP)
   bist_definition (
      address  IA (array = 6:0;);
      data_in  I (array =  59:0;);
      data_out A (array =  59:0;);
      write_enable WE low;
      chip_enable CE low;
      clock CK high;
      control DM (array =  59:0;) high;
      dont_touch SLP low input;
        tech = "55 nm SRAM";
        version = "MEMORY COMPILER 2006.01.00";
        message = "SRAM Without Redundancy";
        min_address = 0;
        max_address = 127;
        data_size = 60;
  read_write_port(
        read_cycle (
            change IA;   // new address changes
            wait;
            assert CE;
            wait;
            assert CK;
            wait;
            expect A move;   // get accessed addressed data out
         write_cycle (
            wait;
            assert CK;
            wait;
            change I;    // get input data
            wait;
            assert WE;
            wait;
            assert CE;
            wait;        // all write cycle complete
发表于 2014-5-1 07:32:06 | 显示全部楼层
你编写的与调用的SRAM IP的名字是不是一致的?
 楼主| 发表于 2014-5-5 09:25:40 | 显示全部楼层
问题已解决,自问自答吧:是add new controller和add memory model中,RAM数量设置不一致导致的问题。RAM的mbist model本身编写的没有问题。
GMT+8, 2025-12-13 02:26 , Processed in 0.017649 second(s), 7 queries , Gzip On, Redis On.
