查看: 9182|回复: 16
[求助]verdi3 201210破解问题
发表于 2014-4-28 15:47:30 | 显示全部楼层 |阅读模式
电脑环境 虚拟机下ubuntu 14.04安装软件 Verdi3 201210
按照论坛的方法,用了http://bbs.eetop.cn/viewthread.php?tid=428165提供的破解方法。
但是在运行了lmgrd之后,显示如下内容后就卡住了。。。。
  1. lee@ubuntu:~$ lmgrd
  2. lee@ubuntu:~$ 15:38:21 (lmgrd) -----------------------------------------------
  3. 15:38:21 (lmgrd)   Please Note:
  4. 15:38:21 (lmgrd)
  5. 15:38:21 (lmgrd)   This log is intended for debug purposes only.
  6. 15:38:21 (lmgrd)   In order to capture accurate license
  7. 15:38:21 (lmgrd)   usage data into an organized repository,
  8. 15:38:21 (lmgrd)   please enable report logging. Use Acresso Software Inc.'s
  9. 15:38:21 (lmgrd)   software license administration  solution,
  10. 15:38:21 (lmgrd)   FLEXnet Manager, to  readily gain visibility
  11. 15:38:21 (lmgrd)   into license usage data and to create
  12. 15:38:21 (lmgrd)   insightful reports on critical information like
  13. 15:38:21 (lmgrd)   license availability and usage. FLEXnet Manager
  14. 15:38:21 (lmgrd)   can be fully automated to run these reports on
  15. 15:38:21 (lmgrd)   schedule and can be used to track license
  16. 15:38:21 (lmgrd)   servers and usage across a heterogeneous
  17. 15:38:21 (lmgrd)   network of servers including Windows NT, Linux
  18. 15:38:21 (lmgrd)   and UNIX. Contact Acresso Software Inc. at
  19. 15:38:21 (lmgrd)   www.acresso.com for more details on how to
  20. 15:38:21 (lmgrd)   obtain an evaluation copy of FLEXnet Manager
  21. 15:38:21 (lmgrd)   for your enterprise.
  22. 15:38:21 (lmgrd)
  23. 15:38:21 (lmgrd) -----------------------------------------------
  24. 15:38:21 (lmgrd)
  25. 15:38:21 (lmgrd)
  26. 15:38:21 (lmgrd) FLEXnet Licensing (v11.6.0.0 build 60117 amd64_re3) started on ubuntu (linux) (4/28/2014)
  27. 15:38:21 (lmgrd) Copyright (c) 1988-2008 Acresso Software Inc. All Rights Reserved.
  28. 15:38:21 (lmgrd) US Patents 5,390,297 and 5,671,412.
  29. 15:38:21 (lmgrd) World Wide Web:  http://www.acresso.com
  30. 15:38:21 (lmgrd) License file(s): /usr/EDA/license.dat
  31. 15:38:21 (lmgrd) lmgrd tcp-port 35244
  32. 15:38:21 (lmgrd) Starting vendor daemons ...
  33. 15:38:21 (lmgrd) Started snslmgrd (internet tcp_port 41925 pid 2832)
  34. 15:38:22 (snslmgrd) FLEXnet Licensing version v11.6.0.0 build 60117 amd64_re3
  35. 15:38:22 (snslmgrd) Server started on ubuntu for:        DataExpansion
  36. 15:38:22 (snslmgrd) DataExpansionCoverage DataExpansionSim DataReplay
  37. 15:38:22 (snslmgrd) DataReplaySim        Debussy                Debussy_shared
  38. 15:38:22 (snslmgrd) EssentialSignalAnalysis Extraction        FLE_main
  39. 15:38:22 (snslmgrd) FL_cosim_run        FL_ice_run        FL_multichip_partition
  40. 15:38:22 (snslmgrd) FL_recalc        Gaia                Gate2LayoutCorrelation
  41. 15:38:22 (snslmgrd) Gate2RTLCorrelation Gsim_dump_advance Gsim_dump_basic
  42. 15:38:22 (snslmgrd) Gsim_framework_advance Gsim_framework_basic Gsim_snapshot
  43. 15:38:22 (snslmgrd) Gsim_wave        GuidedTraceAnalysis HDL2SC_mixed
  44. 15:38:22 (snslmgrd) HDL2SC_verilog        HDL2SC_vhdl        Laker_AMS
  45. 15:38:22 (snslmgrd) Laker_L1        Laker_L2        Laker_L3
  46. 15:38:22 (snslmgrd) Laker_T1        Laker_T1_LE        Laker_Viewer
  47. 15:38:22 (snslmgrd) Laker_iDRC        Laker_iLVS        Reusner
  48. 15:38:22 (snslmgrd) RtlGateCorrelation SKDB_Import        SilVE
  49. 15:38:22 (snslmgrd) Siloti                Siloti_fe        Siloti_o2
  50. 15:38:22 (snslmgrd) SimVE                TLM_Synthesis        TestDesignCorrelation
  51. 15:38:22 (snslmgrd) TestVE                TimingAnalysis        Verdi
  52. 15:38:22 (snslmgrd) WhatIfAnalysis        hdlin                hdlin_mixed
  53. 15:38:22 (snslmgrd) hdlin_verilog        hdlin_vhdl        nAnalyzer
  54. 15:38:22 (snslmgrd) nBench                nClock                nCompare
  55. 15:38:22 (snslmgrd) nECO                nESL                nMonitor
  56. 15:38:22 (snslmgrd) nProp                nSchema                nSchemaOnly
  57. 15:38:22 (snslmgrd) nState                nTiming                nTrace
  58. 15:38:22 (snslmgrd) nTree                nWave                nlcc
  59. 15:38:22 (snslmgrd) tSchema                turboSchema        turboState
  60. 15:38:22 (snslmgrd) turboTracer        turboWave        nLint
  61. 15:38:22 (snslmgrd) nLint_either        nLint_mixed        nLint_sv
  62. 15:38:22 (snslmgrd) nLint_verilog        nLint_vhdl
  63. 15:38:22 (snslmgrd) EXTERNAL FILTERS are OFF
  64. 15:38:22 (lmgrd) snslmgrd using TCP-port 41925
  65.
    复制代码
然后就不动了,等了几个小时还是不动。。。求解
发表于 2014-4-28 15:57:53 | 显示全部楼层
Have you start Verdi ? If yes, you should see more messages.
This is a daemon running in background, so you can try to start Verdi to test if this daemon is working or not.
 楼主| 发表于 2014-4-28 16:01:02 | 显示全部楼层
回复 2# hyperpicc
   多谢提醒...
发表于 2014-5-5 17:27:00 | 显示全部楼层
lmgrd只是启动verdi的license,输入verdi,后直接起来
发表于 2014-9-9 17:07:11 | 显示全部楼层
我没有安装成功,说license不对,求帮助。
发表于 2014-10-5 21:38:38 | 显示全部楼层
很好,很实用
发表于 2014-12-19 16:37:46 | 显示全部楼层
謝謝分享
发表于 2015-4-9 18:43:37 | 显示全部楼层
按照4楼在 停留的界面 中直接输入Verdi,就Ok了,但是要注意cshrc路径是 2012.10/bin/ 和 licene.dat中Daemon中路径保持一致 2012.10/bin/,  我一直不成功的原因是配置Verdi 2013.07一直有问题,路径指向了2012.10/platform/LINUX/了,后改回来就Ok了. 供参考。。。。。
发表于 2015-6-15 19:26:39 | 显示全部楼层
谢谢,辛苦了
发表于 2015-6-18 15:24:15 | 显示全部楼层
感謝分享!
GMT+8, 2025-12-18 03:36 , Processed in 0.036116 second(s), 6 queries , Gzip On, Redis On.
