查看: 2664|回复: 0
[求助] 求助关于VHDL实现累加器
发表于 2014-4-27 17:40:55 | 显示全部楼层 |阅读模式
就是会随着每个时钟上升沿加一,然后输出八位二进制数。。。。
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
entity xiangwei is
port(   rst : in std_logic;
         clk : in std_logic;
         SHLout  : out std_logic_vector(7 downto 0));
            end;
architecture rtl of xiangwei is
begin
    process(clk)
     variable suanzhu : std_logic_vector(7 downto 0):="00000000";
     begin
        if (clk'event and clk='1') then
            if(rst='0') then
                suanzhu:="00000000";
             end if;
             if(rst='1') then
                if(suanzhu<256) then
                      suanzhu:=suanzhu+1;
                      SHLout<=suanzhu;
                 else
                 end if;
             end if;
        end if;
                 end process;
end;
GMT+8, 2025-12-25 05:31 , Processed in 0.965898 second(s), 8 queries , Gzip On, Redis On.
