楼主: mabas.masood
[其它] Agilent GoldenGate RFIC Simulation Software 2013.10 - 4.8.3 + FIX
发表于 2015-12-9 17:18:16 | 显示全部楼层
Perfect!
发表于 2015-12-9 17:19:38 | 显示全部楼层
GOOD!!!!!
发表于 2016-1-6 15:02:02 | 显示全部楼层
thank you
发表于 2016-1-6 15:30:39 | 显示全部楼层
does it work?
发表于 2016-1-11 02:01:28 | 显示全部楼层
vdfvddfdsfdsfdsfsdfsd
发表于 2016-7-14 01:46:32 | 显示全部楼层
为什么我的ADE simulator选项中就没有goldengate呢?单独用ggsim可以仿真,但是集成不到ADE环境里,求助!!
发表于 2016-7-14 14:36:29 | 显示全部楼层
Thanks a lot
发表于 2017-5-22 12:05:30 | 显示全部楼层
回复 36# UnknownGuest
   解决了么,我的出现不能连接到license file 或者license file不能支持用户,还有我的ADE仿真器设置要么只有ADSsim 要么只有goldengate,大家有没有出现这个问题的,求解决。
发表于 2017-7-6 08:37:25 | 显示全部楼层
gooooooooooooooooooooooood
发表于 2017-7-20 13:08:16 | 显示全部楼层
Can't make directory /usr/tmp/.flexlm, errno: 2(No such file or directory)
13:05:49 (lmgrd) license manager: can't initialize:Cannot find license file.
13:05:49 (lmgrd) The license files (or license server system network addresses) attempted are
13:05:49 (lmgrd) listed below.  Use LM_LICENSE_FILE to use a different license file,
13:05:49 (lmgrd) or contact your software provider for a license file.
13:05:49 (lmgrd) Filename: "/usr/local/flexlm/licenses/license.dat"
13:05:49 (lmgrd) License Path: "/usr/local/flexlm/licenses/license.dat"
13:05:49 (lmgrd) FLEXnet Licensing error:-1,359
13:05:49 (lmgrd) System Error:2 No such file or directory
13:05:49 (lmgrd) For further information, refer to the FLEXnet Licensing documentation,available at "www.acresso.com".
怎么解决找不到license.dat的问题?
GMT+8, 2025-9-16 03:01 , Processed in 0.016252 second(s), 3 queries , Gzip On, Redis On.
